- Overview
- Pre-installation
- Cluster administration- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management- uipathctl config additional-ca-certificates
- Upgrade
- Authentication- uipathctl config argocd generate-dex-config
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- Product-specific configuration- uipathctl config orchestrator
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
List past
               input.json/cluster_config.jsonfiles applied to the cluster.
               The output is always in tabular format. By default, the list is sorted by version number.
uipathctl manifest list-revisions [flags]uipathctl manifest list-revisions [flags]# List revisions of the current cluster
# List revisions of the cluster identified by the current context in the kubeconfig file
uipathctl manifest list-revisions  --kubeconfig cluster.kubeconfig# List revisions of the current cluster
uipathctl manifest list-revisions  --kubeconfig cluster.kubeconfig-h, --help               help for list-revisions
    --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
    --show-command       if true, prints the commands corresponding to stored revisions as the last column  -h, --help               help for list-revisions
    --show-command       if true, prints the commands corresponding to stored revisions as the last column--context string      name of the kubeconfig context to use
    --versions string     optional path to versions file    --context string      name of the kubeconfig context to use
