uipathctl reference guide
Last updated Feb 28, 2026
uipathctl registry uninstall-temp-registry
Uninstall the temporary docker registry
uipathctl registry uninstall-temp-registry [flags]
Options
  -h, --help           help for uninstall-temp-registry
  -i, --input string   Specify input json file
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
