uipathctl reference guide
uipathctl cluster
Reference for the uipathctl cluster command and its subcommands for managing cluster-related operations in Automation Suite.
Description​
Manage cluster-related commands.
uipathctl cluster [flags]
Options​
  -h, --help   help for cluster
Options inherited from parent command​
  • Description​
  • Options​
  • Options inherited from parent command​
Connect
Stay updated
