uipathctl reference guide
uipathctl config additional-ca-certificates
Reference for the uipathctl config additional-ca-certificates command and its subcommands for managing CA certificates in Automation Suite.
Description​
Manage additional CA certificates.
uipathctl config additional-ca-certificates [flags]
Options​
  -h, --help   help for additional-ca-certificates
Options inherited from parent commands​
      --versions string     optional path to versions file)
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
