uipathctl reference guide
Last updated Apr 28, 2025
uipathctl prereq create
Creates the external prerequisites. These are primarily object storage buckets and SQL databases. The SQL databases required for the installation are created on the SQL server if the sql.create_db key is set in the config file. The object storage buckets are created in the cloud provider if the object_storage.create_bucket key is set in the config file.
uipathctl prereq create PATH [flags]uipathctl prereq create PATH [flags]
Examples
# Create all external prerequisites
uipathctl prereq create input.json/cluster_config.json --versions versions.json# Create all external prerequisites
Options
-h, --help                help for create
      --location location   Location where the prerequisites are executed. one of [local, cluster] (default cluster)
  -o, --output output       output format. one of [json,yaml,text] (default text)
      --versions string     Path to the versions file  -h, --help                help for create
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
      --upgrade             include upgrade-related checks      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
