uipathctl reference guide
Last updated Feb 28, 2026
uipathctl snapshot restore history
Show the restore history.
uipathctl snapshot restore history [flags]
Options
  -h, --help   help for history
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
