uipathctl reference guide
Last updated Apr 28, 2025
uipathctl config
Manage config.
uipathctl config [flags]uipathctl config [flags]
Options
-h, --help   help for config    -h, --help   help for config
      --versions string     optional path to versions file      --context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent commands
