uipathctl reference guide
uipathctl service aicenter
uipathctl service aicenter command flags and subcommands for managing AI Center-related services in Automation Suite.
Manager AICenter related services.
Options
  -h, --help   help for aicenter
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
