uipathctl reference guide
uipathctl prereq run
uipathctl prereq run command for running prerequisite checks to validate that an Automation Suite installation will succeed.
Runs the prerequisite checks to validate that the installation would succeed.
uipathctl prereq run PATH [flags]
Examples
# Runs all the prerequisite checks
uipathctl prereq run input.json/cluster_config.json --versions versions.json
Options
  -h, --help              help for run
  -o, --output output     output format. one of [json,yaml,text] (default text)
  -v, --verbose           verbose output
      --versions string   path to versions file
      --list-options      list all available options for the included and excluded flags
      --excluded strings    components to be excluded from execution, defaults to none
      --included strings    components to be included in the execution, defaults to all
      --upgrade             include upgrade-related checks
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
