- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl config generate
- uipathctl config kubeconfig
- uipathctl config products
- uipathctl config products scale-down
- uipathctl config products scale-up
- uipathctl registry
- uipathctl registry cleanup
- uipathctl registry hydrate-temp-registry
- uipathctl registry seed
- uipathctl registry seed-internal-registry
- uipathctl registry uninstall
- uipathctl registry upload
- uipathctl registry validate
- uipathctl rke2
- uipathctl rke2 disk
- uipathctl rke2 update-fqdn
- uipathctl rke2 gpu
- uipathctl rke2 node
- uipathctl rke2 node remove
- uipathctl rke2 objectstore
- uipathctl rke2 objectstore uninstall
- uipathctl rke2 registry
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- uipathctl config kerberos-auth
- uipathctl config kerberos-auth global-config
- uipathctl config kerberos-auth global-config update
- uipathctl config kerberos-auth service-config
- uipathctl config kerberos-auth service-config update
- uipathctl config windows-auth
- uipathctl config windows-auth update
- Monitoring and alerting
- uipathctl config
- uipathctl config alerts
- uipathctl config telemetry
- uipathctl config telemetry get
- uipathctl config telemetry set
- uipathctl resource
- uipathctl resource constraint-report
- uipathctl resource report
- uipathctl service
- uipathctl service aicenter
- uipathctl service aicenter configure
- Troubleshooting
uipathctl reference guide
Last updated Apr 28, 2025
Load the configuration file found in the parameter, and lists the applications created based on it. The runtime configuration is used to determine which applications are required. The output is always in tabular format. By default, the list is sorted alphabetically.
uipathctl manifest list-applications PATH [flags]uipathctl manifest list-applications PATH [flags]# List the applications which are installed based on the configuration found in input.json
uipathctl manifest list-applications input.json
# List the applications which are installed based on the configuration found in input.json.
# Sort them by the order in which they need to be installed based on dependencies between them.
uipathctl manifest list-applications input.json/cluster_config.json --sort-by topological
# List the applications without headers
uipathctl manifest list-applications input.json/cluster_config.json --no-headers
# Override the initial list of enabled components
uipathctl manifest list-applications input.json/cluster_config.json --override gatekeeper,redis
-h, --help help for list-applications
--is-required string to check whether the component needs to install
--no-headers if true, print the output without headers
--override strings optional list of components to override the components enabled in input.json file
--sort-by sortBy if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical) -h, --help help for list-applications
--sort-by sortBy if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical) --context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 5h0m0s)
--versions string optional path to versions file --context string name of the kubeconfig context to use
