uipathctl reference guide
Last updated Feb 24, 2025
uipathctl config argocd registry
Manage registry secrets for ArgoCD.
Options
-h, --help   help for registry  -h, --help   help for registry
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
