OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl manifest render
Load the configuration found at PATH, and render it on stdout.
uipathctl manifest render PATH [flags]uipathctl manifest render PATH [flags]
Options
-h, --help                   help for render
--include-config         include cluster wide config in the diff
--include-dependencies   include dependencies in the diff
  -o, --output output          output format. one of [json,yaml] (default yaml)  -h, --help                   help for render
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
