- Overview
- About uipathctl
- uipathctl reference documentation
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
About uipathctl
You have been redirected to the first page of the Automation Suite documentation for the 2023.4 version.
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
About uipathctl
uipathctl
is a UiPath® command-line tool that allows you to perform various operations in Automation Suite on EKS/AKS.
You can use uipathctl to check prerequisites in your environment, install Automation Suite, as well as configure and manage it from a single unified CLI.
For more information, including a complete list of
uipathctl
operations, see the uipathctl reference documentation.
You can install
uipathctl
on the Linux, macOS, and Windows platforms.
Note:
Currently,
uipathctl
is only compatible with the x86 architecture.
You cannot run uipathctl
on machines based on the ARM architecture,
such as Macs with Apple Silicon (M series) CPUs.
