uipathctl reference guide
Last updated Feb 24, 2025
uipathctl config enable-basic-auth
Enable basic auth enables basic sign-in for the provided organization.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config enable-basic-auth [flags]uipathctl config enable-basic-auth [flags]
Examples
        # Enable basic auth for the provided organization in cluster
        uipathctl config enable-basic-auth --orgname organization
        # Enable basic auth for the provided organization in the cluster identified by the current context in the kubeconfig file
        uipathctl config enable-basic-auth --orgname organization --kubeconfig cluster.kubeconfig        # Enable basic auth for the provided organization in cluster
Options
  -h, --help             help for enable-basic-auth
      --orgname string   organization name  -h, --help             help for enable-basic-auth
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
© 2005-2026 UiPath. All rights reserved.
