- Release Notes
- Getting Started
- Permissions
- Role Description and Matrix
- Collaborator Roles Information and Matrix
- Understanding the Roles and Collaborator Roles
- Citizen Developer Roles and Collaborator Roles
- Starting as
- Admin Console
- Workspace
- Explore
- Submit a new entry
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Hub - Maestro integration
- Automation Store
- Additional Resources
Automation Hub User Guide
Specific Roles and Collaborator Roles are made available to support the Citizen Developers towards managing Automation submissions and flow within the platform. Please find below two tables containing the Citizen Developer default roles and Collaborator Roles along with the permissions assigned to each of them.
- These roles cannot be edited, disabled, or deleted because they are connected to the way the Automation Hub works.
- You can assign multiple roles to the user account and, for each role, define the categories corresponding to the type of access you want the user to have.
- For details about the other roles available in the platform please check the .
Role |
Description |
Citizen Developer Self User |
Automate low-risk, simple tasks/activities only for their own usage; Access to Share automations. |
Citizen Developer Power User |
Automate low risk, simple/medium task/activities or processes for users from their own department/team or for themselves; Access to Share automations; Access to the Automation Pipeline page to view and select automations that they want to develop. |
Business Reviewer |
Push forward automations created by a Citizen Developer Self User and select which automations are worth being endorsed for a technical review. |
Technical Reviewer |
Identify code quality issues and approve automations for large consumption. |
Permission Matrix
Citizen Developer Automations
Action |
Business Reviewer |
View Automations Access to built by the citizen developer. |
Y |
Y |
Y |
Y |
Share an Automation Access to share an automation built using Studio/StudioX, in order to have it reviewed for consumption by a larger audience. |
Y |
Y | ||
Access to All and Review tables to perform Business Review of Automations |
Y | |||
Access to All and Review tables to perform Technical Review of Automations |
Y |
Automation ideas
Action |
Business Reviewer |
View an idea Access to view the information available in any based on the categories you have been assigned to. |
Y |
Y |
Y |
Y |
Components
Action |
Business Reviewer |
View Components Access to view the reusable components which have passed the curation process and are now published. |
Y |
Y |
Y |
Y |
Download any published Component Access to download the package of any reusable component displayed in Explore Components. |
Y |
Y |
Y |
Y |
Upload a Component Access to the Upload Component option which allows the user to upload a reusable component and submit it for curation. |
Y |
Y |
Y |
Y |
- Citizen Developer Submitter collaborator role cannot be manually assigned to users. It is automatically assigned following the submission of an automation, respectively when a Citizen Developer clicks the Start Development option.
- Citizen Developer collaborator can be manually assigned to users only if the Make this role assignable option is turned on.
Collaborator Role |
Description |
Citizen Developer Submitter |
Automatically assigned to any user who shared an automation. |
Citizen Developer |
Start development for the selected automations; Update the Source Code file; Document your code in the Development Specifications Document; Create and link reusable components to the automation initiative; Fix bugs and provide support during UAT and hypercare period; Create the Move to Production checklist. |
