uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- uipathctl cluster upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Load the configuration found at the path provided in the argument and drive the state of the cluster to it.
The command will perform a diff between the current state of the cluster and the desired state, and apply the changes to the cluster.
Unlike the apply command, the upgrade command will not install any component that is not already installed.
When the --override flag is present, the list will override the selection found in the input file. The flag is mutually exclusive with the --only flag. When the exclude_components key is present in the input file, the components found in the list are excluded from the installed components. This has the highest priority over all the other flags and it is not mutually exclusive with any of them.
uipathctl cluster upgrade PATH [flags]
Examples
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl cluster upgrade input.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl cluster upgrade input.json --kubeconfig cluster.kubeconfig --versions versions.json
# Apply the configuration but skip the components installed directly by helm
uipathctl cluster upgrade --skip-helm input.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl cluster upgrade --override automation_hub,orchestrator --versions versions.json
Options
-h, --help help for upgrade
--no-wait if true, return immediately after the ArgoCD applications are created
--only strings optional exclusive list of components to apply
--override strings optional list to override the components enabled in input.json file
--skip-helm if true, skip components installed directly by helm
--versions string path to versions file
