OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
uipathctl cluster
Manage cluster-related commands.
uipathctl cluster [flags]uipathctl cluster [flags]
Options
  -h, --help   help for cluster  -h, --help   help for cluster
Options inherited from parent command
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Options
  • Options inherited from parent command
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
