Process Mining
Letzte Aktualisierung 15. Okt. 2025
Effizienz – Lieferantenleistung
Effizienz – Lieferantenleistung ist das Dashboard, in dem Sie die Leistung Ihrer Lieferanten im Purchase-to-Pay-Prozess analysieren können. Es zeigt detaillierte Informationen zu den pünktlichen Liefertarifen, den Gesamtwerten pro Lieferant und der Anzahl eindeutiger Lieferanten pro Kategorie an.
Supplier performance overview
Check out KPIs for a detailed description of the KPIs related to supplier performance.
Dahsboard charts
The following table describes the dashboard charts of the Efficiency - Order process velocity dashboard.
ChartBeschreibung
Supplier analysisDisplays supplier performance and activity metrics for the end-to-end process, helping evaluate supplier efficiency, reliability, and impact on overall process performance.
One time supplier analysisDisplays purchasing activity across material groups, showing how many suppliers are used and how many of them are one-time suppliers. This enables you to identify cases where suppliers were used only once, which can reveal inefficiencies or highlight opportunities for supplier consolidation.
TrendsThe graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order creation date.
Note: You can select different metrics and fields to change the context.
  • Supplier performance overview
  • Dahsboard charts
Hilfe erhalten
UiPath Community-Forum
Vertrauen und Sicherheit
© 2005–2025 UiPath. Alle Rechte vorbehalten
