- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Configuring log rules
Reference for configuring Robot log ingestion rules and conditions for Insights in Automation Suite.
Robot logs capture diagnostic and execution logs. You can configure the conditions for which Robot logs are ingested by Insights. For example, you only want to capture logs for Processes that include a specific name.
For details, refer to Robot logs.
Configure Log Rules
You can configure the Orchestrator settings in the nlog.custom.config file. To modify the settings, take the following steps:
Place the new log rules inside the
nlog.custom.configfile. Check the following details for an example:{ "10_Robot_Insights": { "logger": "Robot.*", "ruleName": "insightsRobotLogsRule", "minLevel": "Info", "writeTo": "insightsRobotLogs", "enabled": false, "final": false, "filters": { "defaultAction": "Ignore", "conditions": [ { "condition": "level >= LogLevel.Error or ends-with('${message}', ' execution ended')", "action": "Log" } ] } } }{ "10_Robot_Insights": { "logger": "Robot.*", "ruleName": "insightsRobotLogsRule", "minLevel": "Info", "writeTo": "insightsRobotLogs", "enabled": false, "final": false, "filters": { "defaultAction": "Ignore", "conditions": [ { "condition": "level >= LogLevel.Error or ends-with('${message}', ' execution ended')", "action": "Log" } ] } } } -
Use the Orchestrator Configurator Tool to update the configuration. Use the following command to merge the keys from the custom
nlog.custom.configfile with the settings already available in theorchestrator-customconfigconfiguration map../orchestrator-configurator.sh -l nlog.custom.config./orchestrator-configurator.sh -l nlog.custom.configThis command does not remove any existing settings.
Log Rules Example
In the following example, we are only sending logs that exceed a certain level or contain the message that the execution has ended:
"minLevel": "Info",
"enabled": false,
"final": false,
"filters": {
"conditions": [
"action": "Log"
"minLevel": "Info",
"enabled": false,
"final": false,
"filters": {
"conditions": [
"action": "Log"
