Last updated May 5, 2025
How to generate the encoded pull_secret_value for external registries
To generate the base64 encoded pull_secret_value, take the following steps:
  1. Log in to the external registry using Docker. Use the following command:
    docker logindocker login
  2. Generate the base64 encoded string of your Docker configuration .json file, using the following command:
    cat ~/.docker/config.json | base64 -w0cat ~/.docker/config.json | base64 -w0
