Roles and policies
The the following table describes the IAM roles and policies that the CloudFormation template creates:
Table 1. IAM roles
Role Actions
CopyRole
This role is used to copy objects between S3 buckets. It is a copy of the https://github.com/aws-quickstart/lambda-copyzips AWS repository initially used for the AWS QuickStart.
File: copy-zips.template.yaml
  • s3:GetObject
  • s3:PutObject
  • s3:DeleteObject
ACMCertificateRole
The purpose of this role is to create and verify an ACM certificate using DNS validation and Route 53. It is a copy of the https://github.com/aws-quickstart/quickstart-aws-acm-certificate AWS repository used for the AWS QuickStart.
File: quickstart-aws-acm-certificate.template.yml
  • acm:RequestCertificate
  • acm:DescribeCertificate
  • acm:DeleteCertificate
  • route53:ChangeResourceRecordSets
VPCFlowLogsRole
This role serves as the value of the DeliverLogsPermissionArn parameter in the AWS::EC2::FlowLog resource type. Is it a copy of the https://github.com/aws-quickstart/quickstart-aws-vpc QuickStart repository. File: aws-vpc.template.yaml
  • logs:CreateLogStream
  • logs:PutLogEvents
  • logs:DescribeLogGroups
  • logs:DescribeLogStreams
AutomationAssumeRole
This role is used for various SSM documents ( AWS::SSM::Document ), with the following purposes:
  • AgentRemoveInstanceDocument : remove the agent instance from the cluster;
  • ServerRemoveInstanceDocument : remove the server instance from the cluster;
  • RegisterAiCenter : register the AI Center service to Orchestrator;
  • OnDemandBackup : create a snapshot of the Automation Suite cluster;
  • OnDemandRestoreDocument : restore the Automation Suite cluster from a given snapshot;
  • GetBackupList : get the list of avaliable snapshots of the Automation Suite cluster;
  • UpdateAMIDocument : update AMI for the scalling groups.
AutomationAssumeRole allows full access to Amazon SSN. For more information, see AmazonSSMFullAccess . File: ec2-management.template.yaml
  • autoscaling:CompleteLifecycleAction
  • autoscaling:RecordLifecycleActionHeartbeat
  • autoscaling:UpdateAutoScalingGroup
  • ssm:SendCommand
  • autoscaling:DescribeAutoScalingGroups
  • ssm:PutParameter
  • ssm:GetParameter
  • logs:PutLogEvents
  • logs:CreateLogGroup
  • ec2:DescribeImages
  • ec2:DescribeLaunchTemplates
  • ec2:DescribeLaunchTemplateVersions
  • iam:PassRole
  • ec2:CreateLaunchTemplateVersion
  • ec2:RunInstances
  • states:StartExecution
  • states:DescribeExecution
StateMachinesAssumeRole
This role is used for the OnDemandRestoreStateMachine resource ( AWS::StepFunctions::StateMachine ). This resource is used for the restore operation.
StateMachinesAssumeRole allows full access to Amazon SSN. For more information, see AmazonSSMFullAccess . File: ec2-management.template.yaml
Uses the AmazonSSMFullAccess managed policy.
EventsBridgeAssumeRole
This role is used for the following event rules ( AWS::Events::Rule ):
  • AsRobotsTerminateEventRule
  • AgentTerminateEventRule
  • ServerTerminateEventRule
The rules are for the terminate lifecycle action.
  • ssm:StartautomationExecution
  • iam:PassRole
ObjectStorageBucketsCleanupLambdaRole
This role is used for the ObjectStorageBucketsCleanupFunction lambda function and provides utility for the object storage. File: external-storage.template.yaml
  • s3:GetAccelerateConfiguration
  • s3:GetBucketLocation
  • s3:GetBucketVersioning
  • s3:ListBucket
  • s3:ListBucketVersions
  • s3:ListBucketMultipartUploads
  • s3:DeleteObject
  • s3:DeleteObjectVersion
  • logs:PutLogEvents
  • xray:PutTraceSegments
ServiceFabricIamRole
This role is referenced in the following resources:
  • ServiceFabricInstanceProfile ( AWS::IAM::InstanceProfile )
  • The following policies ( AWS::IAM::Policy ): LogsAccessPolicy , LifecycleHookActionsPolicy , Ec2QueryPolicy , QuickstartS3IAMPolicy , InputJsonSecretPolicy , KubeconfigSecretPolicy , InstallerDownloadUrlParameterPolicy , ExternalStorageAccessPolicy .
File: uipath-sf.template.yaml
Uses the AmazonSSMManagedInstanceCore managed policy.
AsgProcessModificationRole
This role is used to modify the ASG processes during CF stack creation.
  • autoscaling:ResumeProcesses
  • autoscaling:SuspendProcesses
  • logs:PutLogEvents
FindAmiLambdaRole
This role is used by the FindAMIFunction lambda function. File: uipath-sf.template.yaml
  • logs:PutLogEvents
CreateInputJsonLambdaRole
This role is used by the CreateInputJsonFunction lambda function. The function creates the configuration file for the Automation Suite installation. File: uipath-sf.template.yaml
  • secretsmanager:GetSecretValue
  • secretsmanager:PutSecretValue
  • autoscaling:DescribeAutoScalingInstances
  • logs:PutLogEvents
  • ec2:DescribeInstanceTypes
  • ec2:DescribeInstanceTypeOfferings
ComputeResourceSizeLambdaRole
This role is used by the ComputeResourceSizeFunction lambda function. The function validates that the input for resources is in accordance with the hardware requirements. File: uipath-sf.template.yaml
  • ec2:DescribeInstances
  • ec2:RunInstances
  • ec2:CreateTags
  • cloudformation:DescribeStacks
  • logs:PutLogEvents
Table 2. IAM policies
Policy Actions
LogsAccessPolicy
Policy for log access.
  • logs:PutLogEvents
  • cloudwatch:PutMetricData
Policy for lifecycle hook access.
Ec2QueryPolicy
Policy for EC2 and ASG access.
  • ec2:DescribeVolumes
  • ec2:DescribeTags
Policy for getting access to the QS S3 bucket.
s3:GetObject
Policy for allowing access to the secret manager.
Policy for allowing access to SSM parameters.
ssm:GetParameter
Policy for allowing access to external storage.
  • s3:GetBucketAcl
  • s3:GetBucketCORS
  • s3:GetBucketNotification
  • s3:GetBucketPolicy
  • s3:PutBucketPolicy
  • s3:DeleteBucketPolicy
  • s3:ListBucket
  • s3:PutBucketAcl
  • s3:PutBucketCORS
  • s3:*Object
  • s3:*ObjectAcl
  • s3:*ObjectAttributes
  • s3:*ObjectVersion
  • s3:*ObjectVersionTagging
  • s3:AbortMultipartUpload
  • s3:ListMultipartUploadParts
  • s3:ListAllMyBuckets
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
