- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Automation Suite supports High Availability Add-on (HAA) installed either in the same cluster or on external machines.
You must configure HAA to enable the actual HA setup for the multi-node setup. To do that, you can either provide the HAA license to the installer or install HAA on the external machines and give the HAA configurations to the installer.
In-cluster Redis High Availability Add-on configuration
In a multi-node HA-ready production setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services runs on a single node and represents a single point of failure. Therefore, if you have not purchased a High Availability Add-on (HAA) license, a cache node failure or restart will result in downtime for the entire cluster. To prevent such an incident, you can purchase HAA, which enables redundant, multi-node HA-ready production deployment of the cache.
All installations include the HAA software with a single-node license. This license is free of cost, no purchase required.
If you wish to enable HAA across multiple nodes, then purchasing an HAA license is required. This will implement full high availability for the cluster in a multi-node HA-ready production setup.
HAA is based on Redis technology.
To do that, take the following steps:
- Purchase an HAA license. Contact UiPath® for details.
- Update the following fields in the
cluster_config.jsonfile:fabric.redis.license- enter the HAA license converted to a single base64 string. You need to encode the entire license key to base64, including the text-----LICENSE START----- and -----LICENSE END-----. In bash, you can do that using the following command:echo '-----LICENSE START-----<license_key_here>-----LICENSE END-----' | base64 -w0echo '-----LICENSE START-----<license_key_here>-----LICENSE END-----' | base64 -w0fabric.redis.ha- usetrueto enable HAA and make sure to also configure thefabric.redis.licenseparameter. This enables HAA database replication and increases the number of HAA pods to 3. By default,fabric.redis.hais set tofalse.Note:If
redis.hais enabled,redis.licenseneeds to be set to a license that supports more than two shards."fabric": { "redis": { "ha": "true", "license": "Base64String" // Replace Base64String with the encoded full license string. } }"fabric": { "redis": { "ha": "true", "license": "Base64String" // Replace Base64String with the encoded full license string. } }
- Rerun the fabric installer:
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement
Updating the Redis license
To update the Redis license, take the following steps:
Set up kubectl and ArgoCD access:
- Enable kubectl access on the primary node. Refer to Enabling kubectl for instructions.
- Enable access to ArgoCD. Refer to Accessing ArgoCD for instructions.
Check the current license status:
To check the status of the current license, run the following Shell command:
kubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jqkubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jq- Clusters deployed after the expiry date of the license included in the installer will show the trial 4-shard license that expires in 30 days, as in the following example:
- Clusters that were already running when the license expired will show the following status:
Update the existing license:
To update the existing license, run the following Shell command:
kubectl patch application fabric-installer -n argocd \ --type=json -p '[{"op":"add","path":"/spec/source/helm/parameters/-","value":{"name": "global.redis.license", "value": "<LICENSE_KEY_IN_BASE64>"}}]'kubectl patch application fabric-installer -n argocd \ --type=json -p '[{"op":"add","path":"/spec/source/helm/parameters/-","value":{"name": "global.redis.license", "value": "<LICENSE_KEY_IN_BASE64>"}}]'
To see if the change was applied, access ArgoCD. Refer to Accessing ArgoCD for instructions.
If the fabric-installer application appears out of sync, and the sync process was not triggered automatically, select the Sync button yourself. This may be happen if you are using an older Automation Suite version.
Note:There is a small delay between the moment the ArgoCD UI shows the app synced and when the Redis operator successfully applies the new license.
To see logs from the Redis operator when it tries to apply the license, run the following command:
kubectl logs -n redis-system --since=300s -l name=redis-enterprise-operator -c redis-enterprise-operator --tail=-1 | grep licensekubectl logs -n redis-system --since=300s -l name=redis-enterprise-operator -c redis-enterprise-operator --tail=-1 | grep license
If you try to apply an expired license, or you run the installer that ships with an expired license, you will get the following output:
To update the Redis license used by older installers before running them, update the
fabric.redis.licensekey in the<installer_folder>/defaults.json:
Check that the new license is applied:
To check if the new license is applied, run the following Shell command:
kubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jqkubectl get rec -n redis-system redis-cluster -o jsonpath='{.status.licenseStatus}' | jqIn the following image you can see that the Redis cluster switched from the trial 30-day license to a single-shard 10-year license.
External High Availability Add-on configuration
When opting for an Active/Active configuration of Automation Suite, an external cluster-hosted High Availability Add-on is mandatory. In all other situations, it is merely optional.
To configure High Availability Add-on, you must update the following parameters in the cluster_config.json file:
| Parameter | Description |
| Provide the FQDN of the High Availability Add-on (HAA) server. |
| Provide the password to connect to the HAA server. |
| Provide the port for the HAA server. |
fabric.redis.tls | Enable the TLS protocol. By default, TLS is enabled. If a certificate is required when TLS is enabled, make sure to provide it via the |
"fabric": {
"redis": {
"hostname": "redis_fqdn",
"password": "credential_to_connect_redis",
"port": 6380,
"tls": true,
"fabric": {
"redis": {
"port": 6380,
"tls": true,
