- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring SQL databases
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Hardware and software requirements
To find out more about the core concepts used in an Automation Suite deployment, see Glossary.
The default installation experience includes a choice of two product selections:
- Complete (All products) – Install the complete list of products available in Automation Suite. For details, see Automation Suite products.
Select products – Allows you to select and install only the products you are interested in. Note, however, that the installer takes the cross-product dependencies into consideration. That means that if a product requires the installation of another product, you must install both of them. For details, see Cross-product dependencies.
Note:You can enable additional products later in the same deployment at any point in time, after the initial installation, without having to reinstall. For details, see Managing products.
We recommend validating the hardware requirements based on expected usage and ensuring the deployment has enough capacity before adding additional products. For details, see Capacity planning.
You can deploy Automation Suite in either single-node evaluation or multi-node HA-ready production mode. While most of the prerequisites for the two profiles are identical, multi-node HA-ready production mode requires additional resources.
Once the deployment starts, you cannot switch or upgrade from one deployment profile to another. Before choosing your deployment profile, see Supported use cases for single-node and multi-node installations.
Prerequisite type |
Prerequisite |
Hardware |
Note:
To avoid potential installation issues, make sure that all nodes used in the deployment are set to the same time zone. |
General machine requirements | |
Requirements specific to the following products:
Supported RHEL version and ipcalc tool installed on all the Linux machines. For details about RHEL compatibility with Automation Suite versions, see RHEL compatibility matrix. Note:
We support new minor versions of RHEL within 90 days of their release. We support SELinux with default policies. | |
FIPS 140-2 | |
Load balancer L4 / Network Load Balancer | |
NFS server requirement (on-premises or cloud-managed NFS server with NFSv3/NFSv4 version on Linux based)
Node ports | |
Software |
RPM packages on each machine |
SQL Server | |
Objectstore (Azure Blob storage, AWS S3, S3 compatible objectstore) | |
OCI-compliant registry | |
DNS | |
TLS 1.2+ | |
IPv4
(IPv6 is not supported) | |
Swap memory must be disabled. | |
- You need root permission to install and deploy Automation Suite. For more on the specific components that require root access, see Root privileges requirement.
Cilium requires CAP_SYS_ADMIN permissions to function correctly. Make sure these permissions are granted.
- Having scan agents running on your system may cause installation or runtime failures, due to the changes they make to the IPTables. To avoid this behavior, configure your scan agent so that it does not interfere with the Automation Suite installation.
- UiPath® does not prescribe specific firewall or developer tool configurations as long as the Automation Suite requirements are met. Based on our observations, a limited number of external tools can interfere with the smooth operation of Automation Suite. If such issues arise, contact the relevant vendor for help. For additional guidance, see the Automation Suite responsibility matrix.
Before you begin, consider the following:
- Automation Suite supports Federal Information Processing Standard 140-2 (FIPS 140-2). You can perform a clean installation
of Automation Suite on a FIPS 140-2-enabled host. You can also enable FIPS 140-2 on a machine where you previously performed
an Automation Suite installation. For details, see Security and compliance.
Note:
Insights is currently not supported on FIPS-enabled hosts. Make sure to disable Insights when installing Automation Suite on a FIPS-enabled host.
- The minimum hardware requirements do not protect the deployment from node failures.
- The multi-node HA-ready production profile is resilient to only one node failure. This means that you can lose only one server node. This restriction does not apply to agent nodes. You can lose as many agent nodes and still continue to use the cluster without downtime as long as enough overall cluster capacity is available.
- You can increase the server node tolerance to failure by following the instructions in Advanced installation experience.
The following sections list out the hardware requirements for both the Complete product selection and individual products.
The following sections describe the hard requirements for the Complete product selection.
General requirements
Hardware for all products |
Single-node minimum requirement |
Multi-node minimum requirements |
Processor per cluster |
32 (v-)CPU/cores |
96 (v-)CPU/cores |
Minimum processor per node |
N/A |
8 (v-)CPU/cores |
RAM |
64 GB |
192 GB |
Minimum RAM per node |
N/A |
16 GB |
Cluster disks* |
256 GB SSD Min IOPS: 1100 |
Data disk
512 GB SSD Min IOPS: 1100 |
etcd disk
16 GB SSD Min IOPS: 240 |
UiPath® bundle disk
Objectstore
*The cluster disks capacity may need to be increased based on your AI Center ML skills and training storage requirements.
If you install Automation Suite in single-node evaluation mode, and you do not have a machine with 32 (v-)CPU/cores and 64 GB of RAM, you can bring machines with a minimum of 8 (v-)CPU/cores and 16 GB of RAM. For more details, see Capacity calculator.
If you choose this option, follow the multi-node installation and configuration instructions.
It is recommended to bring external objectstore whenever possible. This helps in scaling the objectstore independently of the cluster, and brings additional stability. We support the following objectstore options:
- Azure storage account
- AWS S3 storage bucket
- S3 compatible storage bucket
For details on the hardware requirements your must meet to install individual products or various product combinations in Automation Suite, use the Automation Suite Install Sizing Calculator.
Additional Task Mining requirements
Task Mining requires an additional agent node that must meet the following requirements:
Hardware |
Minimum requirement |
Processor |
20 (v-)CPU/cores |
RAM |
60 GB |
Cluster binaries and state disk |
Data disk |
N/A |
Additional Automation Suite Robots requirements
In multi-node HA-ready production environments, Automation Suite Robots require an additional agent node. In single-node evaluation environments, an additional Automation Suite Robots node is optional.
The hardware requirements for the Automation Suite Robots node depend on the way you plan to use your resources. In addition to the additional agent node requirements, you also need a minimum of 10 GB to enable package caching.
The following sections describe the factors that impact the amount of hardware the Automation Suite Robots node requires.
Robot size
The following table describes the required CPU, memory, and storage for all robot sizes.
Size |
CPU |
Memory |
Storage |
Small |
0.5 |
1 GB |
1 GB |
Standard |
1 |
2 GB |
2 GB |
Medium |
2 |
4 GB |
4 GB |
Large |
6 |
10 GB |
10 GB |
Agent node size
The resources of the Automation Suite Robots agent node have an impact on the number of jobs that can be run concurrently. The reason is that the number of CPU cores and the amount of RAM capacity are divided by the CPU/memory requirements of the job.
For example, a node with 16 CPUs and 32 GB of RAM would be able to run any of the following:
- 32 Small jobs
- 16 Standard jobs
- 8 Medium jobs
- 2 Large jobs
Job sizes can be mixed, so at any given moment, the same node could run a combination of jobs, such as the following:
- 10 Small jobs (consuming 5 CPUs and 10 GB of memory)
- 4 Standard jobs (consuming 4 CPUs and 8 GB of memory)
- 3 Medium jobs (consuming 6 CPUs and 12 GB of memory)
Kubernetes resource consumption
Given that the node is part of a Kubernetes cluster, the Kubernetes agent present on the server (kubelet) consumes a small amount of resources. Based on our measurements, the kubelet consumes the following resources:
- 0.6 CPU
- 0.4 GB RAM
A node similar to the one previously described would actually have approximately 15.4 CPUs and 31.6 GB of RAM.
Automatic machine size selection
All your cross-platform processes have the Automation Suite Robots option set to Automatic by default. This setting selects the appropriate machine size for running the process using serverless robots.
When automatically choosing the size, the criteria listed in the below table are evaluated in order. As soon as one criterion is satisfied, the corresponding machine size is chosen and the remaining criteria are not evaluated.
Order |
Criterion |
Machine size |
1 |
Remote debugging job |
Medium |
2 |
Process depends on UI Automation OR Process depends on the UiPath Document Understanding activities |
Standard |
3 |
Other unattended process |
Small |
Additional AI Center and Document Understanding requirements
On top of the core service requirements that are part of full platform requirements, AI Center requires additional resources, depending on the models that you want to run or train. For more details about the required GPU hardware generations and compatible NVIDIA drivers, refer to Compatibility Matrix.
AI Center requires disk storage at runtime for the ML Skills and for the training pipeline, as follows:
The ML Skills require disk space on the
/var/lib/rancher
partition for storing the trained model for predictions. In the worst case scenario, the model size can be as big as 20 GB. -
The training pipeline consumes the storage from the
/var/lib/rancher
partition for hosting the model. In the worst case scenario, the model size can be as big as 20 GB, and additionaly, it can require storage for the dataset. The minimum size of the dataset storage can be 51 GB; its recommended size is 105 GB. This must be on the dedicated disk for AI Center. The training pipeline only schedules on the node on which the dedicated AI Center disk is attached.
The following table describes the additional resources AI Center needs. In the following table, Data Disk is needed on all server nodes. Data Disk is not needed on agent nodes.
Use |
CPU |
RAM (GB) |
GPU |
Disk (GB) |
Minimum for serving (ML Skill, one replica) |
0.6 |
2 |
0 |
Minimum for Training (Pipeline) |
1 |
4 |
0 |
DU model Serving (ML Skill, one replica) |
1 |
4 |
0 |
DU model Training |
2 |
24 |
Strongly recommended |
Use |
CPU |
RAM (GB) |
GPU |
Disk (GB) |
Small implementation:
4 |
32 |
0 |
Average implementation:
8 |
52 |
rancher
partition = 80 GB on the rancher
partition
2 1 pipeline * 105GB = 105 Data disk
rancher
partition = 160 GB on the rancher
partition
4 (2 pipeline + 1 DU pipeline) * 105GB = 315 Data disk
Additional AI Computer Vision requirements
This setup works on on-premises Nvidia GPUs, but also works with cloud providers such as AWS, Azure and GCP. Suggested GPU types include those from the RTX, Tesla, and Ampere family of products which have enough GPU memory and processing capability.
The main difference between these two types of GPUs is that the ones with virtualization usually have more GPU RAM and are offered by most cloud providers. Having more GPU RAM increases the maximum size of the image you can input to the model. In conclusion, virtualization GPUs are not significantly faster that the consumer GPUs.
You need a machine with the following hardware specifications:
Hardware specification | Requirements |
Memory |
CPU |
GPU |
Storage |
Additional Document Understanding recommendations
For increased performance, you can install Document Understanding on an additional agent node with GPU support. Note, however, that Document Understanding is fully functional without the GPU node. Actually, Document Understanding uses CPU VMs for all its extraction and classification tasks, while for OCR we strongly recommend the usage of a GPU VM.
For more details about the CPU/GPU usage within the Document Understanding framework, refer to CPU and GPU Usage.
If you want to use an additional node with GPU support, you must meet the following requirements:
Hardware |
Processor |
8 (v-)CPU/cores |
RAM |
52 GB |
Data disk |
N/A |
GPU RAM |
11 GB |
For more details, check the AI Center considerations section.
Before starting the Automation Suite installation, you must ensure you meet the following requirements:
- you have a RHEL subscription
- you enabled the BaseOS and AppStream repositories
- you installed the required RPM packages
The following table lists the required RPM packages:
RPM package |
Description |
Required on nodes for installation. |
Required on nodes for the execution of the readiness check. |
Required for offline installations only. |
RHEL 8.4 and later have the required RPM packages in the BaseOS and AppStream repositories by default.
If you perform a manual clean installation of Automation Suite, you must ensure you meet the RPM package requirements. In this case, you are responsible for installing the required RPM packages.
If you upgrade from a previous Automation Suite version, you have already installed the RPM packages.
For details on the tools you can use to install and validate RPM packages, see Validating and installing the required RPM packages.
The installation requires an external SQL server as a prerequisite. Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
Individual product support varies.
For each product you plan to deploy, you must:
- check the supported version of SQL Server as required by the product
- apply the SQL Server configuration prerequisites, including SQL Server User permission, as required by the product
For more information on product-specific SQL Server requirements, see Configuring Microsoft SQL Server.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
- 8 (v-)CPU
- 32 GB RAM
- 256 GB SSD
These minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation.
For each product you plan to deploy, you must evaluate projected usage and apply the capacity planning guidance as specified by the product. This information is available in the help section of each individual product.
To enable a backup, you need an external NFS server. Automation Suite supports Linux-based on-premises or cloud-managed NFS servers, version NFSv3/NFSv4.
The general minimum hardware requirements for NFS Server are as follows:
CPU - 4 vCPU
RAM - 8 GB
Storage - 1 TB
Note: If you use an external objectstore, the storage requirement is a few GBs. If you use an in-cluster objectstore, the minimum storage size is the same as the size of the objectstore.
To configure an Active/Passive deployment, make sure you meet the following requirements:
- Hardware
- Load balancers
- DNS
- Certificates
- Objectstore
- Traffic Manager
Both Automation Suite clusters must meet a set of software and hardware requirements. For details, see the hardware requirements for the multi-node mode.
Both Automation Suite clusters must have a load balancer. For details, see Configuring the Load balancer.
For details of the DNS requirements, see Configuring the DNS.
For details of the certificate requirements, see Certificate requirements.
You must also add the SANs to the certificate if you opened the DNS.
The following table lists the RHEL versions supported by each version of Automation Suite:
Automation Suite version |
Supported RHEL versions |
2023.10.9 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5 |
2023.10.8 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4, 9.5 |
2023.10.7 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4 |
2023.10.6 | 8.6, 8.8, 8.9, 8.10, 9.2, 9.4 |
2023.10.5 |
8.6, 8.8, 8.9, 8.10, 9.2 |
2023.10.4 |
8.6, 8.8, 8.9 |
2023.10.3 |
8.6, 8.8, 8.9 |
2023.10.2 |
8.6, 8.8, 8.9 |
2023.10.1 |
8.6, 8.8 |
2023.10.0 |
8.6, 8.8 |
kernel-4.18.0-372.91.1.el8_6
and kernel-4.18.0-477.10.1.el8_8
are affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite
nodes uses these kernel versions either pre- or post-installation.
- Terminology
- Product selection
- Choose your deployment profile
- Prerequisites at a glance
- Hardware requirements
- Complete product selection: hardware requirements
- Individual products: hardware requirements
- RPM package requirements
- Manual installations
- Cloud templates
- Microsoft SQL Server general requirements
- NFS Server general requirements
- Disaster recovery - Active/Passive requirements
- Hardware
- Load balancer
- DNS
- Certificates
- Objectstore
- RHEL compatibility matrix
