- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Complete post-deployment operations after deploying Automation Suite to AWS Marketplace via CloudFormation.
This page provides instructions on the operations you can perform after deploying Automation Suite to AWS.
Validating the installation
- Under CloudFormation > Stacks, you can find all of your deployments.
- Select the stack you deployed, a status of CREATE_COMPLETE indicates the deployment has completed successfully.
Updating certificates
The installation process generates self-signed certificates on your behalf. By default, these certificates are compliant with FIPS 140-2 and expire after 1825 days, but you can choose any of the following expiry periods at the time of deployment: 90, 365, 730, 1825, or 3650 days.
You must replace the self-signed certificates with certificates signed by a trusted Certificate Authority (CA) as soon as the installation completes. If you do not update the certificates, the installation will stop working after the certificate expiry date.
If you installed Automation Suite on a FIPS 140-2-enabled host and want to update the certificates, make sure they are compatible with FIPS 140-2.
For instructions, refer to Managing certificates.
Enabling FIPS 140-2
After completing an Automation Suite installation using the AWS deployment template, you can enable FIPS 140-2 on your machines. For instructions, refer to Security and compliance.
Accessing the installer package
In AWS deployments, the installer package containing all the scripts for post-deployment operations is decompressed in the /root/installer directory.
Accessing the deployment outputs
From the Stack you selected, select the Output tab on the top. On this tab, you should have access to all the information you need for next steps.
For any of the credentials, you can access them via the secrets link provided in the table. Select on the link and go to Retrieve Secret Value for the credentials.
Key Value Description ArgoCD https://alm.${CONFIG_CLUSTER_FQDN}You can use the ArgoCD console to manage installed products. ArgoCD Secret < See link in console > Credentials for ArgoCD Automation Suite Secret < See link in console > Credentials for Automation Suite Portal Cluster Administration URL https://${CONFIG_CLUSTER_FQDN}/uipath-managementPortal centralizes the resources required to complete an Automation Suite installation and perform common post-installation operations. Automation Suite URL https://${CONFIG_CLUSTER_FQDN}Automation Suite Portal Host Administration Portal https://${CONFIG_CLUSTER_FQDN}The host portal is for system administrators to configure the Automation Suite instance. The settings that you configure from this portal are inherited by all your organizations, and some can be overwritten at the organization level. Host Administration Secret < See link in console > Credentials for Host Administration Interface Tour Interface tour The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all the Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages. Rancher https://monitoring.${CONFIG_CLUSTER_FQDN}Automation Suite uses Rancher to provide cluster management tools out of the box. This helps you manage the cluster and access monitoring and troubleshooting. Dashboard (Grafana) Monitoring URL https://monitoring.${CONFIG_CLUSTER_FQDN}/dashboardThe URL to dashboard (Grafana) monitoring tools Metrics (Prometheus) Monitoring URL https://monitoring.${CONFIG_CLUSTER_FQDN}/metricsThe URL to metrics (Prometheus) monitoring tools. Alertmanager Monitoring URL https://monitoring.${CONFIG_CLUSTER_FQDN}/alertmanagerThe URL to Alertmanager monitoring tools.
Accessing the Cluster Administration portal
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, refer to Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
Go to the following URL: https://${CONFIG_CLUSTER_FQDN}/uipath-management.
You do not need any credentials to access the Cluster Administration portal.
Accessing the Automation Suite portal
The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
- Go to the following URL:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Default organization.
- The username is orgadmin.
- Retrieve the password by selecting the secrets link provided in the output table for AutomationSuiteSecret. Go to Retrieve Secret Value for the credentials.
Accessing host administration
The host portal is where system administrators configure the Automation Suite instance. The settings configured from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Host organization.
- The username is admin.
- Retrieve the password by selecting the secrets link provided in the output table for HostAdministrationSecret. Go to Retrieve Secret Value for the credentials.
Accessing ArgoCD
To access ArgoCD, take the following steps:
https://alm.${CONFIG_CLUSTER_FQDN}. - The username is admin if you want to use the ArgoCD admin account, or argocdro if you want to use the ArgoCD read-only account.
- Retrieve the password by selecting to the secrets link provided in the output table for ArgoCdSecret. Go to Retrieve Secret Value for the credentials.
Accessing the monitoring tools
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
- Username: admin
- Password: to retrieve the password , run the following command:
kubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -dkubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -d
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
- Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" - Run the following command to update the password:
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f --accept-license-agreement./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f --accept-license-agreement
Accessing cluster VMs
Navigate to EC2 and find your Automation Suite instance(s) depending if you deployed single-node or multi-node.
Find the public IP of the Bastion or instance you want to connect to.
Open a terminal and use SSH to connect to Bastion.
ssh -i <path_to_private_key> <username>@<bastion_ip>ssh -i <path_to_private_key> <username>@<bastion_ip> -
From Bastion, you can access other nodes via SSH using the following command. The username must be the same as the one used to connect to Bastion.
ssh -i .ssh/private_key <username>@<node_address>ssh -i .ssh/private_key <username>@<node_address>
Performing cluster operations
The templates provide automations for cluster operations leveraging Systems Manager documents.
Using Systems Manager documents
To use the Systems Manager documents, take the following steps:
Go to the Systems Manager service.
In the left menu, select Documents.
In the Owned by me tab, select the SSM document you want to run.
Select the Execute automation button.
Fill in the parameters and select the Execute button.
UpdateAMIDocument
The SSM document creates a new Launch Template version for the server and agent Automatic Scaling Groups with an updated AMI ID.
Usage
The document exposes 2 parameters:
ImageName(e.g.:RHEL-8.6*_HVM-20*) - If theImageNameparameter is provided and AMI that matches theImageNamewill be set on the Automatic Scaling Groups;AmiId(e.g.:ami-032e5b6af8a711f30) - If provided, theAmiIdtakes precedence overImageNameand is set on the Automatic Scaling Groups.
If you did not use a custom AMI at deployment time, you can leave the parameters empty. In this case, the ImageName stored in Parameter Store is used as default value.
RegisterAiCenter
The SSM document registers AI Center to the external Orchestrator provided at deployment time.
Usage
The document exposes a single, mandatory, parameter: IdentityToken, which is an installation access token generated by the external Identity service. Since the token has a short availability (approximately 1-2 hours), we recommend generating it just before running the SSM document. For instructions, refer to Installation key.
OnDemandBackup
Creates a snapshot of the Automation Suite cluster. Does not perform a backup on the SQL server.
Usage
This SSM document does not require any parameters.
Execution logs
To check the logs of the file, select the Step ID for the captureOnDemandBackup step.
GetAllBackups
Lists all snapshot available in the Automation Suite cluster.
Usage
Execution logs
To check the list of available snapshots, select the Step ID for the getSnapshotList step.
OnDemandRestore
Restores the Automation Suite cluster to a snapshot.
Usage
The SSM document exposes the SnapshotName parameter. To get a snapshot, use the GetAllBackups document and check the logs.
Execution logs
To view the execution logs, take the following steps:
See the restore flow by selecting State machines.
Select OnDemandRestoreStateMachine.
Select the name of the running execution.
Select the step for which you want to check the execution logs and look in the output section for the
CommandInformation.CommandIdand copy it. -
Go to the Run Command service.
In Command history, search for the command ID you copied earlier.
Select the instance ID.
In the output section, select CloudWatch Logs to see the full logs.
- Validating the installation
- Updating certificates
- Enabling FIPS 140-2
- Accessing the installer package
- Accessing the deployment outputs
- Accessing the Cluster Administration portal
- Accessing the Automation Suite portal
- Accessing host administration
- Accessing ArgoCD
- Accessing the monitoring tools
- Accessing cluster VMs
- Performing cluster operations
- Using Systems Manager documents
- UpdateAMIDocument
- RegisterAiCenter
- OnDemandBackup
- GetAllBackups
- OnDemandRestore
