- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring log rules
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Insights Database works using two tables: dbo and read. Both tables store data from Orchestrator databases and pass data between each other. Over time, tables store a large amount of data that can impact database performance. You can free up space by removing data that is not relevant or outdated.
The estimated threshold for storing historical data is set to
- Up to 100 million jobs
- Up to 1 billion job events
- Up to 100 million queue items
- Up to 500 million queue item events
- Up to 1 billion robot logs
Use the following database maintenance SQL scripts to create SQL Stored Procedures, then execute these SQL Stored Procedures to either delete all data from [dbo].Jobs, [dbo].JobEvents, [dbo].QueueItems, [dbo].QueueItemEvents, [dbo].RobotLogs tables, or just the [dbo].RobotLogs.
Back up your database before executing the scripts. Before running the PROCEDURE [read].[Delete_Insights_Data_Read] and PROCEDURE [read].[Delete_Process_Logs_Read] scripts, the Insights module needs to be disabled.
Considerations
- Scripts with the
_DBOsuffix are used to delete data from DBO schema tables, - Scripts with the
_Readsuffix are used to delete data from Read schema tables. - Large-sized batches might impact the speed of execution. Consider using the default batch size, which is set to 100000.
Prerequisites
Log in to the Automation Suite cluster.
Remove files that may conflict with the commands:
rm -f values.json && rm -f appsettings.jsonrm -f values.json && rm -f appsettings.json -
Get the current settings:
kubectl -n uipath get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jq '.' > values.jsonkubectl -n uipath get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jq '.' > values.json -
Format the settings:
jq '.AppSettings' values.json > appsettings.jsonjq '.AppSettings' values.json > appsettings.json -
Set the
Insights.ModuleEnabledkey toFalse:jq '.["Insights.ModuleEnabled"] = "false"' appsettings.json > temp.json && mv -f temp.json appsettings.jsonjq '.["Insights.ModuleEnabled"] = "false"' appsettings.json > temp.json && mv -f temp.json appsettings.json -
Update the configuration:
./bin/uipathctl config orchestrator update-config --app-settings appsettings.json./bin/uipathctl config orchestrator update-config --app-settings appsettings.json -
Validate the configuration:
kubectl -n uipath get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jqkubectl -n uipath get cm orchestrator-customconfig -o jsonpath='{.data.values\.json}' | jqThe expected result is as follows:
{ "AppSettings": { "Insights.ModuleEnabled": "false" } }{ "AppSettings": { "Insights.ModuleEnabled": "false" } }The result can contain other settings unrelated to Insights.
Run the maintenance scripts. After you run the maintenance script, re-enable Insights using the following steps.
Remove any conflicting files:
Retrieve the current settings:
Remove the
Insights.ModuleEnabledkey:jq 'del(.["Insights.ModuleEnabled"])' appsettings.json > temp.json && mv -f temp.json appsettings.jsonjq 'del(.["Insights.ModuleEnabled"])' appsettings.json > temp.json && mv -f temp.json appsettings.json -
Confirm the configuration:
{ "AppSettings": {} }{ "AppSettings": {} }The result can contain other settings unrelated to Insights.
Resources
SQL stored procedure 1: delete all data based on cut-off timestamp
Generate and save the following SQL Stored Procedures to delete all data types (Jobs, JobEvents, QueueItems, QueueItemEvents, RobotLogs) for a cut-off timestamp.
| SQL Stored Procedures | Parameter | Description |
| Delete_Insights_Data_DBO |
| Delete data from [dbo].[Jobs], [dbo].[JobEvents], [dbo].[QueueItems], [dbo].[QueueItemEvents], [dbo].[RobotLogs] tables based on a cut-off timestamp. |
| Delete_Insights_Data_Read | N/A | Truncate [read].Jobs, [read].JobEvents, [read].QueueItems, [read].QueueItemEvents, [read].RobotLogs tables. |
The Insights Dashboard widgets are available again after SQL Stored Procedure 1 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data. When you first run the Delete_Insights_Data_DBO SQL Script, it creates a QueueItems.IX_CreationTime nonclustered index with the purpose of making future executions faster.
SQL stored procedure 2: delete RobotLogs data based on ProcessNames and Tenant ID
Generate and save this SQL Stored Procedure to delete RobotsLogs based on ProcessNames and Tenant ID.
| Delete_Process_Logs_DBO |
The Orchestrator process name.
Tenant ID is required as two tenants might run processes with identical names.
Delete data in batches of 100000. For details, refer to Considerations. | Delete data from [dbo].[RobotLogs] table by ProcessName and Tenant ID. |
| Delete_Process_Logs_Read |
| Truncate [read].RobotLogs table. |
The Insights Dashboard widgets related to RobotLogs are available again after SQL Stored Procedure 2 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data.
