- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Installation best practices
- Encrypting the SQL Server
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Reference for sudoers file settings that grant admin and regular users access to the Kubernetes cluster and RKE2 files in Automation Suite.
To grant permissions to a specific admin or regular user to access the Kubernetes cluster and RKE2 file, you must update the sudoers file with the required settings.
The following section provides details on the files to which you must grant access to the admin or regular user.
/var/lib/rancher/rke2/bin/kubectlexecutable requires sudo access to operate on cluster resources. To grant the required permissions to the executable without a password, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL = NOPASSWD: /var/lib/rancher/rke2/bin/kubectlUSERNAME ALL = NOPASSWD: /var/lib/rancher/rke2/bin/kubectl/etc/rancher/rke2/stores the following files required to configure or access the cluster:/etc/rancher/rke2/config.yamlfile used to configure the cluster. The default permission for this file is-rw-r--r--. To allow users to modify/etc/rancher/rke2/config.yaml, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/config.yamlUSERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/config.yaml/etc/rancher/rke2/rke2.yamlfile used along with thekubectlcommand to operate on the cluster. The default permission for this file is-rw-------.To allow users to operate on the cluster, update thesudoersfile accordingly. For details, see the following configuration sample:Defaults!/var/lib/rancher/rke2/bin/kubectl env_keep += KUBECONFIGDefaults!/var/lib/rancher/rke2/bin/kubectl env_keep += KUBECONFIG/etc/rancher/rke2/registries.yamlfile required to configure the registry for the cluster. The default permission for this file is-rw-r--r--.To allow users to modify/etc/rancher/rke2/registries.yaml, update thesudoersfile accordingly. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/registries.yamlUSERNAME ALL=NOPASSWD: /usr/local/bin/vim /etc/rancher/rke2/registries.yaml
/var/lib/rancher/rke2/directory stores the cluster related data, which includes kubelet logs, containerized data, static pod configuration files, RKE2 certificates, and etcd data. Admins may be required to read the file and check the size of the directory. To do this, you must give the required permissions to thels,cat, andducommands. For details, see the following configuration sample:USERNAME ALL=NOPASSWD: /usr/bin/ls /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/cat /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/du /var/lib/rancher/rke2/*USERNAME ALL=NOPASSWD: /usr/bin/ls /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/cat /var/lib/rancher/rke2/* USERNAME ALL=NOPASSWD: /usr/bin/du /var/lib/rancher/rke2/*
Note:
For maintenance purposes, we recommend creating a separate file under the /etc/sudoers.d/ directory with the configuration described on this page.
