Failure to compact metrics due to corrupted blocks in Thanos
Fix Thanos compactor failures caused by corrupted blocks in the object store in Automation Suite to prevent excessive Ceph bucket storage use.
Description​
The Thanos compactor may fail to compact metrics when corrupted blocks are detected in the object store. This condition prevents the compactor from processing metrics, leading to increased storage use in the Ceph bucket.
Solution​
To address the issue, take the following steps:
  1. On any server node, run the following script:
    thanosns=monitoring && if kubectl get application -n argocd rancher-monitoring; then thanosns=cattle-monitoring-system; fi && cat <<EOF | kubectl apply -f -
    apiVersion: rbac.authorization.k8s.io/v1
    kind: Role
    metadata:
      annotations:
      labels:
        app.kubernetes.io/component: thanos-cleaner
        app.kubernetes.io/instance: thanos-block-cleaner
        app.kubernetes.io/name: thanos-block-cleaner
      namespace: ${thanosns}
    rules:
    - apiGroups:
      - apps
      resources:
      - statefulsets
      - statefulsets/scale
      verbs:
      - list
      - get
      - update
      - patch
    - apiGroups:
      - batch
      resources:
      - jobs
      - cronjobs
      verbs:
      - delete
      - list
      - get
      - update
      - create
      - watch
    - apiGroups:
      resources:
      - pods
      verbs:
      - delete
      - list
      - get
      - update
    kind: RoleBinding
    metadata:
      labels:
    roleRef:
      apiGroup: rbac.authorization.k8s.io
      kind: Role
    subjects:
    - kind: ServiceAccount
    apiVersion: v1
    metadata:
    apiVersion: monitoring.coreos.com/v1
    kind: PrometheusRule
    metadata:
      namespace: uipath
    spec:
      groups:
      - name: thanos
        rules:
        - alert: ThanosCompactorNotWorking
          annotations:
            description: Thanos compactor is not working. This will disable metrics compaction
              in objectstore bucket. Please check thanos compact pod in ${thanosns} namespace
              for any error. Compactor in faulty state will exhaust object store space
            message: Thanos compactor is not working. Please check if thanos cleaner job
              is functional and able to fix corruption
            runbook_url: https://docs.uipath.com/automation-suite/docs/alert-runbooks
            summary: Thanos compactor is not working
          expr: thanos_compactor_issue{job="thanos-cleaner"} >= 1
          for: 1d
          labels:
            app: thanos
            severity: critical
    EOF
    kind: Role
    metadata:
      annotations:
      labels:
    rules:
    - apiGroups:
      - apps
      resources:
      - statefulsets
      verbs:
      - list
      - get
      - update
      - patch
    - apiGroups:
      - batch
      resources:
      - jobs
      - cronjobs
      verbs:
      - delete
      - list
      - get
      - update
      - create
      - watch
    - apiGroups:
      resources:
      - pods
      verbs:
      - delete
      - list
      - get
      - update
    kind: RoleBinding
    metadata:
      labels:
    roleRef:
      kind: Role
    subjects:
    apiVersion: v1
    metadata:
    metadata:
      namespace: uipath
    spec:
      groups:
      - name: thanos
        rules:
          annotations:
          for: 1d
          labels:
            app: thanos
            severity: critical
    EOF
  2. On any server node, run the following script:
    cat <<'EOF' | kubectl apply -f -
    apiVersion: v1
    data:
      thanos-cleanup.sh: |
        #!/bin/bash
        # Copyright UiPath 2021
        # LICENSE AGREEMENT
        #   Use of paid UiPath products and services is subject to the licensing agreement
        #   executed between you and UiPath. Unless otherwise indicated by UiPath, use of free
        #   UiPath products is subject to the associated licensing agreement available here:
        #   https://www.uipath.com/legal/trust-and-security/legal-terms (or successor website).
        #   You must not use this file separately from the product it is a part of or is associated with.
        set -eu -o pipefail
        export PATH=$PATH:/thanos-bin/
        # Below script removes the blocks which are overlapping or having index issue or having duplicated compaction
        # In few cases with above mentioned scenarios, thanos may skip the compaction and halt the compaction module.
        # Compaction halt requires manual deletion of corrupted blocks and restart of compact pod.
        config_file=/etc/thanos/${THANOS_CONFIG_KEY}
        function info() {
          echo "[INFO] [$(date +'%Y-%m-%dT%H:%M:%S%z')]: $*"
        function warn() {
          echo -e "\e[0;33m[WARN] [$(date +'%Y-%m-%dT%H:%M:%S%z')]:\e[0m $*" >&2
        function error_without_exit() {
          echo -e "\e[0;31m[ERROR][$(date +'%Y-%m-%dT%H:%M:%S%z')]:\e[0m $*" >&2
        function error() {
          exit 1
        function is_compaction_halted() {
          info "Checking if thanos compactor running"
          IFS=" " read -r -a compactor_addresses <<<"$(kubectl get pods -n "$NAMESPACE" -l app.kubernetes.io/instance=thanos-compact -o jsonpath="{.items[*].status.podIP}")"
          is_compactor_halted=0
          if [[ "${#compactor_addresses[@]}" -eq 0 ]]; then
            info "Thanos compactor pod is not running"
            is_compactor_halted=1
          fi
          for ip in "${compactor_addresses[@]}"; do
            #shellcheck disable=SC2086
            halted=$(curl -s http://${ip}:10902/metrics | grep thanos_compact_halted | grep -v '#' | awk -F ' ' '{print $2}')
            if [[ "$halted" -eq "1" ]]; then
              warn "Compaction is halted"
              break
            fi
          done
          return $is_compactor_halted
        function execute_thanos_issue_command() {
          if [[ $# -ne 1 ]]; then
            error "missing issue name for execute_thanos_issue_command function"
          fi
          issue=$1
          info "Checking for issue $issue"
          cmd_ret=0
          verify_output=$(thanos tools bucket --objstore.config-file=${config_file} verify --log.format=json -i $issue 2>&1) && true || cmd_ret=1
          if [[ $cmd_ret -eq 1 ]]; then
            error_without_exit "Output of $issue command: -> $verify_output"
            error "Failed to verify bucket for $issue"
          fi
          echo $verify_output
        function fix_index_issue() {
          info "Fixing index_known_issue issue"
          verify_output=$(execute_thanos_issue_command "index_known_issues")
          for b in $(echo $verify_output | sed 's/} {/\r\n/g' | grep err | grep "detected issue" | awk -F '"id":' '{print $2}' | awk -F ',' '{print $1}' | tr -d '"'); do
            info "Block=$b is having the issue, removing it.."
            thanos tools bucket mark --id="$b" \
              --marker=deletion-mark.json \
              --details="deleted by job" \
              --objstore.config-file="${config_file}"
            info "Block=$b is marked for deletion"
          done
          info "Fixing index_known_issue issue done"
        function fix_overlapping_issue() {
          info "Fixing overlapped_blocks issue"
          overlap_output=$(execute_thanos_issue_command "overlapped_blocks")
          while IFS= read -r line; do
            for b in $(echo $line | awk -F '"overlap":' '{print $2}' | awk -v search="ulid" 'match($0, search) {print substr($0, RSTART)}' | sed 's/ulid/\r\nulid/g' | awk -F ',' '{print $1}' | grep '^ulid' | awk -F ': ' '{print $2}'); do
            done
          done < <(echo "$overlap_output" | sed 's/} {/\r\n/g' | grep "found overlapped blocks")
          info "Fixing overlapped_blocks issue done"
        function fix_duplicate_issue() {
          info "Fixing duplicated_compaction issue"
          duplicate_output=$(execute_thanos_issue_command "duplicated_compaction")
          #shellcheck disable=SC2086,SC2006
          for b in $(echo $duplicate_output | sed 's/ts=2/\r\n2/g' | grep "Found duplicated blocks that are ok to be removed" | awk -F 'ULIDs="' '{print $2}' | tr -d '[]' | awk -F '"' '{print $1}'); do
          done
          info "Fixing duplicated_compaction issue done"
        if [[ -z "$NAMESPACE" ]]; then
          error "NAMESPACE is not set"
        fi
        # We will check if compaction is halted or not before checking for issues
        if is_compaction_halted; then
          info "Thanos compaction is working"
          echo "thanos_compactor_issue 0" | curl --data-binary @- "http://pushgateway-prometheus-pushgateway.uipath.svc.cluster.local:9091/metrics/job/thanos-cleaner"
          exit 0
        fi
        warn "Thanos compactor is not working. Checking for corrupted blocks..."
        echo "thanos_compactor_issue 1" | curl --data-binary @- "http://pushgateway-prometheus-pushgateway.uipath.svc.cluster.local:9091/metrics/job/thanos-cleaner"
        if [[ "$DISABLE_BLOCK_CLEANER" == true ]]; then
          info "DISABLE_BLOCK_CLEANER is set to $DISABLE_BLOCK_CLEANER, skipping block clean"
          exit 0
        fi
        info "DISABLE_BLOCK_CLEANER is set to $DISABLE_BLOCK_CLEANER, removing corrupted blocks"
        replica=$(kubectl get sts -n "$NAMESPACE" thanos-compact -o jsonpath='{.spec.replicas}')
        # compactor must not be running while deleting blocks
        info "Stopping compactor"
        kubectl scale sts -n "$NAMESPACE" thanos-compact --replicas=0
        kubectl delete pods -n "$NAMESPACE" -l app.kubernetes.io/instance=thanos-compact --force
        # fixing index_known_issues
        info "Checking blocks having issue"
        fix_index_issue
        fix_duplicate_issue
        info "Triggering deletion of all marked blocks"
        thanos tools bucket cleanup --delete-delay=0 --objstore.config-file=${config_file}
        info "Corrupted blocks are deleted"
        info "Scaling thanos compactor's replica to $replica"
        kubectl scale sts -n "$NAMESPACE" thanos-compact --replicas=$replica
        info "Thanos compactor started"
      validate-cronjob.sh: |
        #!/bin/bash
        # LICENSE AGREEMENT
        set -eu -o pipefail
        function info() {
        function warn() {
        function error() {
          exit 1
        alias kubectl='kubectl --cache-dir=/tmp/'
        IFS="," read -ra cronjobs <<<"$CRONJOB_LIST"
        for cr in "${cronjobs[@]}"; do
          #shellcheck disable=SC2206
          name=(${cr//// })
          cronNs=default
          cronName=""
          if [[ ${#name[@]} -gt 2 || ${#name[@]} -lt 1 ]]; then
            error "Invalid cronjob name=$cr"
          fi
          if [[ ${#name[@]} -eq 2 ]]; then
            cronNs=${name[0]}
            cronName=${name[1]}
          else
            cronName=${name[0]}
          fi
          info "Validating cronjob=$cr"
          jobName="${cronName}-sf-job-validation"
          created=1
          info "Creating validation job for $cr"
          kubectl delete job -n "${cronNs}" "${jobName}" --ignore-not-found --timeout=3m
          kubectl create job -n "${cronNs}" --from=cronjob/${cronName} "$jobName" || created=0
          if [[ $created == 0 ]]; then
            error "Failed to create job for $cr"
          fi
          kubectl wait --timeout=20m --for=condition=complete -n "${cronNs}" job/$jobName &
          cpid=$!
          kubectl wait --timeout=20m --for=condition=failed -n "${cronNs}" job/${jobName} && exit 1 &
          fpid=$!
          ret=0
          wait -n $cpid $fpid || ret=1
          kill -9 $cpid || true
          kill -9 $fpid || true
          if [[ $ret -eq 0 ]]; then
            info "Job for $cr is validated/completed"
            #ignore deletion error. if deletion fail then will get caught in next sync. This is to reduce failure during installation
            kubectl delete job -n "${cronNs}" "${jobName}" --timeout=3m || true
          else
            error "Job for $cr failed"
          fi
        done
    kind: ConfigMap
    metadata:
      namespace: cattle-monitoring-system
    EOF
    apiVersion: v1
    data:
        #!/bin/bash
        # LICENSE AGREEMENT
        set -eu -o pipefail
        function info() {
        function warn() {
        function error() {
          exit 1
          fi
              break
            fi
          done
          fi
          issue=$1
          cmd_ret=0
          fi
          echo $verify_output
          done
            done
          done
        fi
          exit 0
        fi
          exit 0
        fi
        fix_index_issue
        fix_duplicate_issue
        #!/bin/bash
        # LICENSE AGREEMENT
        set -eu -o pipefail
        function info() {
        function warn() {
        function error() {
          exit 1
          name=(${cr//// })
          cronNs=default
          cronName=""
          fi
            cronNs=${name[0]}
            cronName=${name[1]}
          else
            cronName=${name[0]}
          fi
          created=1
          fi
          cpid=$!
          fpid=$!
          ret=0
          else
          fi
        done
    kind: ConfigMap
    metadata:
    EOF
  3. Replace SF_K8S_TAG with the correct image tag, then apply the cronjob.
From the installer directory on any server node, get the latest tag:
cat versions/docker-images.json  |grep uipath/sf-k8-utils-rhel | tr -d ',"' | awk -F ':' '{print $2}' |sort |uniq |tail -1
Then update the cronjob block by replacing SF_K8S_TAG with the returned value.
Once updated, paste the entire block in the terminal of any server node:
thanosns=monitoring && if kubectl get application -n argocd rancher-monitoring; then thanosns=cattle-monitoring-system; fi && thanosimage=$(kubectl  get statefulset -n $thanosns thanos-compact -o jsonpath='{.spec.template.spec.containers[0].image}') &&  cat <<EOF | kubectl apply -f -
apiVersion: batch/v1
kind: CronJob
metadata:
spec:
  concurrencyPolicy: Forbid
  failedJobsHistoryLimit: 3
  jobTemplate:
    metadata:
      creationTimestamp: null
    spec:
      backoffLimit: 3
      template:
        metadata:
          annotations:
            sidecar.istio.io/inject: "false"
          labels:
            app.kubernetes.io/name: thanos-cleaner-cronjob
        spec:
          containers:
          - args:
            - /script/thanos-cleanup.sh
            command:
            - /bin/bash
            env:
            - name: NAMESPACE
              valueFrom:
                fieldRef:
                  apiVersion: v1
                  fieldPath: metadata.namespace
            - name: THANOS_CONFIG_KEY
              value: thanos.yaml
            - name: DISABLE_BLOCK_CLEANER
              value: "false"
            image: docker.io/uipath/sf-k8-utils-rhel:SF_K8S_TAG
            imagePullPolicy: IfNotPresent
            resources:
              limits:
                cpu: 200m
                memory: 400Mi
              requests:
                cpu: 20m
                memory: 64Mi
            terminationMessagePath: /dev/termination-log
            terminationMessagePolicy: File
            volumeMounts:
            - mountPath: /script/
            - mountPath: /etc/thanos/
            - mountPath: /thanos-bin/
            - mountPath: /.kube/
            - mountPath: /tmp/
          dnsPolicy: ClusterFirst
          initContainers:
          - args:
            - set -e; cp /bin/thanos /thanos-bin/thanos && chmod +x /thanos-bin/thanos
            command:
            - /bin/sh
            - -c
            image: ${thanosimage}
            resources: {}
            volumeMounts:
          nodeSelector:
            kubernetes.io/os: linux
          restartPolicy: Never
          schedulerName: default-scheduler
          securityContext:
            fsGroup: 3000
            runAsGroup: 2000
            runAsNonRoot: true
            runAsUser: 1000
          serviceAccount: thanos-cleaner
          serviceAccountName: thanos-cleaner
          terminationGracePeriodSeconds: 120
          volumes:
          - emptyDir: {}
          - emptyDir: {}
          - emptyDir: {}
          - name: thanos-objectstore-vol
            secret:
              defaultMode: 420
              secretName: thanos-objectstore-config
          - configMap:
              defaultMode: 420
  schedule: 0 1/6 * * *
  successfulJobsHistoryLimit: 2
  suspend: false
EOF
kind: CronJob
metadata:
spec:
  jobTemplate:
    metadata:
    spec:
      backoffLimit: 3
      template:
        metadata:
          annotations:
          labels:
        spec:
          containers:
          - args:
            command:
            - /bin/bash
            env:
            - name: NAMESPACE
              valueFrom:
                fieldRef:
                  apiVersion: v1
              value: thanos.yaml
              value: "false"
            resources:
              limits:
                cpu: 200m
                memory: 400Mi
              requests:
                cpu: 20m
                memory: 64Mi
            volumeMounts:
            - mountPath: /tmp/
          initContainers:
          - args:
            command:
            - /bin/sh
            - -c
            resources: {}
            volumeMounts:
          nodeSelector:
          securityContext:
            fsGroup: 3000
            runAsGroup: 2000
            runAsNonRoot: true
            runAsUser: 1000
          volumes:
          - emptyDir: {}
          - emptyDir: {}
          - emptyDir: {}
            secret:
              defaultMode: 420
          - configMap:
              defaultMode: 420
  suspend: false
EOF
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
