Enabling or disabling Extended Languages OCR
Note:
To make sure you are eligible for Extended Language OCR in Automation Suite, reach out to your Account executive to understand the required commitments.
Important:
To use the Extended Languages OCR, you need to have a valid license configured. The license is a base64 string file provided by UiPath® over email. To obtain the license, file a support ticket under Document Understanding > Extended Languages OCR License Request. Please note UiPath only issues Extended Languages OCR licenses to end customers of Automation Suite. You need to have a Master Software and Services Agreement signed with UiPath, be a single user of that Automation Suite instance, and have all automations running in the Automation Suite instance, which is solely used by your organization.
Obtaining access to Extended Languages OCR involves acceptance of the following additional terms and conditions:
  • Redistribution of the license by the user to other organizations is strictly prohibited. This license is specifically intended for the use of the Extended Languages OCR as part of UiPath Automation Suite, and solely by the entity to which it is provided.
  • Users are obligated to submit usage reports every quarter, with deadlines on March 31st, June 30th, Sept 30th, and Dec 31st each year. These reports can be produced by navigating to the uipath-as-platform storage container and compressing the folder path aistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001 into a zip file. This zip file is then sent to a UiPath email address that will be provided with the license file. If you are using in-cluster objectstore, refer to How to collect DU usage data with in-cluster objectstore (Ceph) to retrieve the usage reports.
Non-compliance with these conditions will result in the inability to renew Extended OCR licenses. The license file expires after 12 months, so a license renewal is needed every 12 months. There is a one month grace period, after which the container will cease processing requests.
After receiving the license string, continue with the steps from this procedure.
  1. After installing or upgrading Automation Suite, configure the cluster_config.json file.
    Tip:
    You can find the file at the following location: /opt/UiPathAutomationSuite/cluster_config.json.
  2. Add the string for Extended Languages OCR in the cluster_config.json file.
    When receiving the license via email, open the license file with any text editor and copy and paste the string you find inside the license property of the documentunderstanding object.
    Note:
    Make sure that the contents of the file are in base64 format before moving to step 3. If not, convert the content to base64 format before moving to the next step.
  3. If the documentunderstanding object is not yet configured, add it using the following configuration:
    "documentunderstanding": {
        "enabled": true,
        "extendedOcr": {
          "enabled": true,
          "license": "<base64 encoded license string goes here>"
        "enabled": true,
        "extendedOcr": {
          "enabled": true,
    Note:
    If the documentunderstanding object is already configured, copy only the extendedOcr property from the license file without changing any other properties.
  4. Execute the Automation Suite installer again using the following command:
    cd /opt/UiPathAutomationSuite/UiPath_Installer
    ./install-uipath.sh -i cluster_config.json -s -o output.json --accept-license-agreement
  5. Go to the ArgoCD panel, in the Document Understanding section and check if the Extended Languages OCR is displayed.
You can access the Extended Languages OCR using the following endpoint: {FQDN}/<organization_id>/<tenant_id>/du_/extended-ocr.
Report file
Note:
The report file does not contain any document-specific information.
For more information on what the report file includes, check the following sample file:
  "year": 2024,
  "month": 10,
  "report": {
    "type": "UsageResponse",
    "meters": [
        "name": "<container name>",
        "quantity": 12.0
    "apiType": "<api type>",
    "serviceName": "<service name>"
  "year": 2024,
  "month": 10,
  "report": {
    "meters": [
        "quantity": 12.0
  • Report file
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
