No healthy upstream issue
Troubleshooting guide for the no healthy upstream 503 error appearing as a blank page on the Automation Suite portal in Automation Suite.
Description​
When accessing the Automation Suite portal, you my encounter an issue where a blank page appears, displaying the "no healthy upstream" message. The message is accompanied by a 503 error.
This issue is caused by the service not running due to multiple potential causes, such as:
  • maintenance mode is enabled,
  • an issue in the cluster, making the service unhealthy,
  • possible mis-configuration at the network layer.
Solution​
To address the issue, check if the maintenance mode is enabled. If it is, disable it and try to reload the portal.
For more details on the potential causes, it is recommended to run the diagnostic tool.
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
