Objectstore migration
Overview of objectstore migration paths across in-cluster and external configurations depending on upgrade history in Automation Suite.
Automation Suite supports multiple objectstore configurations:
  • In-cluster Ceph on persistent volumes
  • In-cluster Ceph on raw disks, introduced in 2022.10
  • External objectstores
Depending on your current setup and upgrade path, different migration steps may apply. The following table lists the migration guide that applies to each scenario.
Your upgrade pathYour current objectstore setupAction required
Upgrading from Automation Suite 2021.10 or 2022.4 to 2023.10In-cluster Ceph on persistent volumeMandatory before upgrading. Refer to Migrating objectstore from persistent volume to raw disks.
Upgrading from Automation Suite 2022.10 to 2023.10In-cluster Ceph on raw diskNo objectstore migration required.
Any versionSwitching from in-cluster objectstore to an external objectstoreRefer to Migrating in-cluster objectstore to external objectstore.
Any versionTaking a one-time backup or moving data to another Automation Suite clusterRefer to Migrating data between objectstores.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
