- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 1: Saving the connection strings
- Step 2: Creating your organizations in Automation Suite
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
You must manually create your organizations in Automation Suite. The organization name must comply with the following Regex format: '^(?!.*$)[a-zA-Z][A-Za-z0-9]+$'.
The organization name must start with an uppercase or lowercase letter and must contain at least one character after the initial letter. Then, the name can include any combination of alphanumeric characters or underscores. Note, however, that the organization name must not end with an underscore.
For example, valid organization names include Username, user_name1, or User123. Make sure to avoid invalid formats such as _username (does not start with a letter), username_(ends with an underscore), user name (contains a space), or user@name (contains an invalid character).
You do not have to manually create the tenant as the migration tool automatically performs this operation for you. The organization and tenant names do not have to be identical. While the organization name is customizable, the Automation Suite tenant name is the same as the standalone Orchestrator tenant name.
