- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- DNS settings not honored by CoreDNS
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- Service upgrade fails during pre-service script execution
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Failure to add agent nodes in offline environments
- Accessing FQDN returns RBAC: access denied error
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
Architecture diagram
Complete component list
Entry points
The UiPath AWS Marketplace deployment has a single entry point.
Nested stacks
- Uipath-sf:
- SSL stack
- Routing stack
- Server stack
- Database stack
- Backup stack
- Management stack
- Lambda functions (
AWS::Lambda::Function):FindAMIFunction- for finding a matching AMI Id.CreateInputJsonFunction- for creating the configuration used by the Automation Suite installer.ComputeResourceSizeFunction- for computing the minimum EC2 instances hardware configuration needed, based on the selected services and deployment type.
- IAM roles (
AWS::IAM::Role) for the Lambda functions to provide minimum permissions:FindAmiLambdaRoleCreateInputJsonLambdaRoleComputeResourceSizeLambdaRole
- Secrets (
AWS::SecretsManager::Secret) to store sensitive information:RDSPasswordOrgSecretPlatformSecretArgoCdSecretArgoCdUserSecretInputJsonSecretKubeconfigSecret
- SSL Stack (optional)
- Network stack (optional)
- Backup stack (optional):
ClusterBackupStorage(AWS::EFS::FileSystem) - Amazon Elastic File System used to store the backup.SharedStorageSecurityGroup(AWS::EC2::SecurityGroup) - Security group used to allow NFS network connections from the cluster nodes.SharedStorageMountTargetOne(AWS::EFS::MountTarget) - Resource that creates the mount target for the EFS file system and the first private subnet.SharedStorageMountTargetTwo(AWS::EFS::MountTarget) - Resource that creates the mount target for the EFS file system and the second private subnet.SharedStorageMountTargetThree(AWS::EFS::MountTarget) - Optional resource that creates the mount target for the EFS file system and the third private subnet.
- Database stack:
RDSDBInstance(AWS::RDS::DBInstance) - The Amazon RDS DB instance. The DB SKU isdb.m5.2xlarge.DBSubnetGroup(AWS::RDS::DBSubnetGroup) - Private subnet group that contains the private subnets.DbSecurityGroup(AWS::EC2::SecurityGroup) - Security Group allowing access to the DB instance.PMRDSDBInstance(AWS::RDS::DBInstance) - Dedicated Amazon RDS DB instance for Process Mining. Only deployed when Process Mining is enabled and the deployment isMulti Node. The DB SKU isdb.m5.4xlarge.
- Routing stack:NOTE: The Alb and Nlb stacks are mutually exclusive configurations
- Alb stack:
ExternalLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) - Application load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.ELBSecurityGroup(AWS::EC2::SecurityGroup) - The security group applied to the load balancer.HttpsTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group of the load balancer.HttpsListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the load balancer.
- Nlb stack:
ExternalLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) - Network load balancer used to distribute Automation Suite traffic. It can be internal or internet-facing.TcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group of the load balancer.TcpListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the load balancer.
KubeLoadBalancer(AWS::ElasticLoadBalancingV2::LoadBalancer) - Private network load balancer used for node registration.KubeApiTcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group for the node registration traffic of theKubeLoadBalancer.KubeApiTcpListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the node registration traffic of theKubeLoadBalancer.Rke2RegistrationTcpTargetGroup(AWS::ElasticLoadBalancingV2::TargetGroup) - The target group for the node registration traffic of theKubeLoadBalancer.Rke2RegistrationTcpListener(AWS::ElasticLoadBalancingV2::Listener) - The listener for the node registration traffic of theKubeLoadBalancer.RootRecordSet(AWS::Route53::RecordSet) - DNS A record for the FQDN.SubdomainRecordSet(AWS::Route53::RecordSet) - DNS A record for the subdomains of the FQDN.
- Alb stack:
- Management stack:
LifecycleAutomationLogs(AWS::Logs::LogGroup) - Log group for logging events from the SSM automation.ClusterOperationsAutomationLogs- Log group for logging events related to cluster operations.OnDemandRestoreStateMachine(AWS::StepFunctions::StateMachine) - Step function used to orchestrate the restore flow.- SSM Documents (
AWS::SSM::Document) sets of steps used to provide graceful node removal:ServerRemoveInstanceDocumentAgentRemoveInstanceDocumentUpdateAMIDocument- Updates the AMI ID for the Auto Scaling Groups.RegisterAiCenter- Registers AI Center to an external Orchestrator provided at deployment time.OnDemandBackup- Creates a manual snapshot of the Automation Suite cluster.GetBackupList- Retrieves all available snapshots for the Automation Suite cluster.OnDemandRestoreDocument- Restores the Automation Suite cluster from a given snapshot.
- Autoscaling Lyfecycle hooks (
AWS::AutoScaling::LifecycleHook) that allow us to run the SSM documents when an EC2 instance receives an instance termination event:ServerAsgLifeCycleHookTerminatingAgentAsgLifeCycleHookTerminatingAsRobotsAsgLifeCycleHookTerminating
- Event rules (
AWS::Events::Rule) that trigger the execution of the SSM Documents:ServerTerminateEventRuleAgentTerminateEventRuleAsRobotsTerminateEventRule
- IAM roles (
AWS::IAM::Role) needed for running SSM Documents and adding logs to the Log Group:AutomationAssumeRoleEventsBridgeAssumeRoleStateMachinesAssumeRole
Note:AutomationAssumeRoleandStateMachinesAssumeRoleallow full access to Amazon SSN. For more information, refer to AmazonSSMFullAccess. - Server stack:
ServerLaunchConfiguration(AWS::EC2::LaunchTemplate) - EC2 instance configuration for the server nodes. Disk configuration:- OS disk - sku gp3, capacity 256GB
- Cluster disk - sku gp3, capacity 300GB
- etcd disk - sku io1, capacity 32GB
- Data disk - sku gp3, capacity 512GB regardless of the selected services.
- Objectstore disk - sku gp3, capacity 512GB
- Optional disk for Automation Suite Robots package caching - sku gp3, capacity 32GB. The disk is deployed only if the the Automation Suite Robots service is enabled in a single-node deployment
AgentLaunchConfiguration(AWS::EC2::LaunchTemplate) - EC2 instance configuration for the agent nodes. Disk configuration:- OS disk - sku gp3, capacity 128GB
- Cluster disk - sku gp3, capacity 256GB
ASRobotsLaunchTemplate(AWS::EC2::LaunchTemplate) - EC2 instance configuration for the ASRobots nodes. Disk configuration:- OS disk - sku gp3, capacity 128GB
- Robot package caching disk - sku gp3, capacity 32GB
GpuEnabledNode(AWS::EC2::Instance) - Optional GPU node. It has the same disk configuration as an agent.TaskMiningNode(AWS::EC2::Instance) - Optional Task Mining node. Deployed only if the Task Mining service is selected. It has the same disk configuration as an agent.BastionHost(AWS::EC2::Instance) - Optional EC2 instance used to SSH to cluster nodes. It has thet3.largeinstance type and a 200GB gp3 disk.ServerAutoScalingGroup(AWS::AutoScaling::AutoScalingGroup) - Auto scaling group for the servers.AgentAutoScalingGroup(AWS::AutoScaling::AutoScalingGroup) - Auto scaling group for the agents.ASRobotsAutoScalingGroup- Auto scaling Group for dedicated Automation Suite Robots nodes. The capacity of this scaling group is 1 if the deployment isMulti Nodeand the Automation Suite Robots service is enabled, and 0 otherwise.- Optional
ServiceFabricIamRole(AWS::IAM::Role) that has permissions to:- write logs
- read EC2 instances configurations
- download AWS Quickstart resources
- access the Automation Suite installation configuration secret
- access the cluster kubeconfig configuration secret
ServiceFabricSecurityGroup(AWS::EC2::SecurityGroup) - Security Group allowing access to UiPath® applications.BastionSecurityGroup(AWS::EC2::SecurityGroup) - Optional Security Group allowing SSH access to BastionAsgProcessModifierFunction(AWS::Lambda::Function) - Used to modify the ASG processes during CF stack creation.AsgProcessModificationRole(AWS::IAM::Role) - IAM role to provide minimum permissions for theAsgProcessModifierFunction- SSM parameters (
AWS::SSM::Parameter):InstanceAMIIdSSMParameter- Stores the AMI ID of the nodes.InstanceAMIImageNameSSMParameter- Holds the Image Name used at deployment time or updated via theUpdateAMIDocument.
AWS::AutoScaling::LifecycleHook) that allow us to transition EC2 instances to InService state after the installer succeeded:ServerAsgLifeCycleHookLaunchingAgentAsgLifeCycleHookLaunchingASRobotsAsgLifeCycleHookLaunching
Deployment and instance type mapping
The template dynamically computes the hardware needed for the deployment as follows:
- Depending on the services installed, it sets minimum requirements at cluster level.
- Depending on the deployment profile (multi-node or single-node profile), it sets minimum requirements for a single VM.
- Selects the instance types based on their availability in the region you deploy and the aforementioned requirements.
The following table shows the mappings between deployment and possible instance types:
| Deployment type | Instance types |
| Single-node, services selection that needs less than 16 CPUs | c5.4xlarge, c5a.4xlarge, m5.4xlarge, m5a.4xlarge |
| Single-node, services selection that needs more than 16 CPUs | c5a.8xlarge, c5.9xlarge, m5.8xlarge |
| Multi-node, services selection that needs less than 48 CPUs | c5.4xlarge, c5a.4xlarge, m5.4xlarge, m4.4xlarge |
| Multi-node, services selection that needs more than 48 CPUs | c5a.8xlarge, c5.9xlarge, m5.8xlarge, m5a.8xlarge |
