Automation Suite overview
Automation Suite enables you to deploy the complete UiPath® automation platform on containerized platforms such as AKS, a managed Kubernetes service offered by Azure, or EKS provided by Amazon AWS.
While these platforms offer robust options, Automation Suite is compatible with other environments as well:
For an in-depth perspective on each deployment model, refer to Cross-deployment model feature comparison.
Automation Suite includes:
  • The UiPath® server products, with the exception of any new products shipping in Automation Cloud first.
  • All shared suite capabilities that enable you to easily configure the integration with existing enterprise systems, such as AD, AAD, or SAML, across all products; a common experience is offered across the suite for the user, tenant, external applications, and license management.
  • Common end-user portal.
This guide provides documentation for installing Automation Suite on your EKS or AKS cluster.
Key benefits
The following image shows an overview of Automation Suite key benefits and capabilities.
Deployment scenarios
You can deploy Automation Suite in an online or offline environment, with optional proxy use, in either lite mode or multi-node mode.
Security and compliance
Automation Suite is pre-configured with optional OPA policies and network policies to follow the principles of the least privilege. In addition, to control the OPA policies, Automation Suite also bundles an optional Gatekeeper component.
Prerequisites
Before installing Automation Suite, you must make sure that your cluster meets the infrastructure requirements.
Installation
UiPath® provides the uipathctl CLI tool, which handles operations such as running prerequisite validations, installing Automation Suite on your cluster, and performing upgrades.
Post-installation management
Automation Suite provides management operations via uipathctl, such as adding new products, updating certificates, configuring Automation Suite in maintenance mode, taking backups, and monitoring.
Upgrade and migration
This section provides more details on how to upgrade Automation Suite or your infrastructure underneath Automation Suite, and how to migrate from standalone products to Automation Suite.
For details, refer to Upgrade and Migrate standalone products.
Troubleshooting
You can run health checks and tests to help detect issues and whether they are in the infrastructure layer or within Automation Suite.
Evaluation guide
Requirements and installation
The following table provides requirements and installation instructions for Automation Suite.
DetailsInstructions
Requirements and installation instructions for Automation Suite.Automation Suite requirements Automation Suite installation
Platform evaluation
The following table provides platform evaluation tasks and instructions.
DetailsInstructions
Complete an initial platform configuration.Automation Suite Configuration checklist
Connect your first robot.Connecting Attended Robots
Monitor the stack, troubleshoot issues, create alerts, and view dashboards from a centralized location.Troubleshooting tools Using the monitoring stack
Product evaluation
The following instructions take you to the corresponding product guides.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
