- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Disaster recovery: Active/Passive configurations
- Generating the configuration file using a wizard
- AKS input.json example
- EKS input.json example
- Configuring a Kubernetes Secret as a secretstore
- Configuring Azure Key Vault as a secretstore
- Configuring HashiCorp Vault as a secretstore
- Configuring AWS Secrets Manager as a secretstore
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Durable Execution Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Configure Azure Key Vault as a secretstore using Service Principal or Workload Identity authentication on EKS/AKS.
You can configure Azure Key Vault as a secretstore using either of the following methods:
- Service Principal authentication
- Workload Identity authentication
By default, all sensitive data is defined in input.json. You can separate this data into two parts:
input.json- contains only configuration data.- Azure Key Vault - stores credentials securely.
You cannot store certificate paths or certificate-related credentials as part of the secretstore.
All credentials referenced in input.json must exist as secrets in the Azure Key Vault before you configure the secretstore. If any referenced credential is missing from Azure Key Vault, the installation fails.
Using Service Principal authentication
To configure Azure Key Vault as secretstore using Service Principal authentication, take the following steps:.
For
uipathctlto identify that the credentials are stored in the Azure Key Vault, you must add the secretstore section toinput.json, as shown in the following example:"secret_store": { "enabled": true, "provider_configs": [ { "type": "azure", "credentials_secret_name": "azure-service-principal-secret", "refresh_interval": "5m", "name": "azure-secret-store", "environment_type": "PublicCloud", "azure_kv": { "vault_url": "https://eso-azure-kv.vault.azure.net/", "tenant_id": "00000000-0000-0000-0000-000000000000" } } ] }"secret_store": { "enabled": true, "provider_configs": [ { "type": "azure", "credentials_secret_name": "azure-service-principal-secret", "refresh_interval": "5m", "name": "azure-secret-store", "environment_type": "PublicCloud", "azure_kv": { "vault_url": "https://eso-azure-kv.vault.azure.net/", "tenant_id": "00000000-0000-0000-0000-000000000000" } } ] } -
Create a Kubernetes secret that stores the Azure Service Principal credentials, as shown in the following example:
apiVersion: v1 kind: Secret metadata: name: azure-service-principal-secret type: Opaque stringData: clientId: <client-id> clientSecret: <client-secret>apiVersion: v1 kind: Secret metadata: name: azure-service-principal-secret type: Opaque stringData: clientId: <client-id> clientSecret: <client-secret> -
Deploy the secret in the
uipathnamespace using the following command:kubectl apply -f azure-service-principal-secret -n uipathkubectl apply -f azure-service-principal-secret -n uipath -
Update the credential values in
input.jsonto reference secrets stored in Azure Key Vault using the following format:vault/<vault-name>/<key-stored-in-the-vault>vault/<vault-name>/<key-stored-in-the-vault>Where:
vault- static keyword.vault-name- the value ofsecret_store.provider_configs[i].name(for example,azure-secret-store).key-stored-in-the-vault- the name of the secret as stored in Azure Key Vault.Before the change, your credentials might look like this:
"admin_username": "admin", "admin_password": "password","admin_username": "admin", "admin_password": "password",After updating them to reference Azure Key Vault, they should look like this:
"admin_username": "vault/azure-secret-store/admin-username-1234", "admin_password": "vault/azure-secret-store/admin-password-1234","admin_username": "vault/azure-secret-store/admin-username-1234", "admin_password": "vault/azure-secret-store/admin-password-1234",The following image shows the secrets stored in Azure Key Vault.
The following sample displays an input.json configuration with credentials stored in Azure Key Vault.
"apps": {
"enabled": true,
"external_object_storage": {
"account_key": "vault/azure-secret-store/apps-external-object-storage-account-key-1234",
"account_name": "as-storage-account",
"azure_fqdn_suffix": "core.windows.net",
"bucket_name": "uipath-as-platform",
"create_bucket": true,
"enabled": true,
"region": "us-east-1",
"storage_type": "azure",
"use_instance_profile": true
"exclude_components": [],
"account_key": "vault/azure-secret-store/external-object-storage-account-key-1234",
"enabled": true,
"fabric": {
"redis": {
"hostname": "redis-cache.mycompany.com",
"password": "vault/azure-secret-store/fabric-redis-password-1234",
"port": 6380,
"tls": true
"fqdn": "automationsuite.mycompany.com",
"infra": {
"docker_registry": {}
"ingress": {
"gateway_selector": {
"istio": "ingressgateway"
"service_annotations": {
"service.beta.kubernetes.io/azure-load-balancer-internal": "false",
"service.beta.kubernetes.io/azure-load-balancer-ipv4": "ip-address"
"install_type": "online",
"integrationservices": {
"enabled": true,
"istioMinProtocolVersion": "TLSV1_3",
"kubernetes_distribution": "aks",
"orchestrator": {
"enabled": true,
"account_key": "vault/azure-secret-store/orchestrator-external-object-storage-account-key-1234",
"account_name": "os-storage-account",
"bucket_name": "uipath-as-orchestrator",
"enabled": true,
"sql_connection_str": "vault/azure-secret-store/orchestrator-sql-connection-str-1234",
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"platform": {
"enabled": true
"pod_identity": {
"aks_managed_identity_client_id": "client-id",
"enabled": true
"postgresql_connection_string_template_sqlalchemy_pyodbc": "vault/azure-secret-store/postgresql-connection-string-template-sqlalchemy-pyodbc-1234",
"profile": "ha",
"proxy": {
"enabled": true,
"http_proxy": "\u003c\u003chttp://\u003cPROXY-SERVER-IP\u003e\u003e:\u003cPROXY-PORT\u003e",
"https_proxy": "\u003c\u003chttp://\u003cPROXY-SERVER-IP\u003e\u003e:\u003cPROXY-PORT\u003e",
"no_proxy": "paste list from Configuring the cluster section"
"registries": {
"docker": {
"password": "",
"pull_secret_name": "registry-credentials",
"url": "registry.uipath.com",
"username": ""
"helm": {
"password": "",
"username": ""
"secret_store": {
"enabled": true,
"secret_name": "",
"type": "azure",
"is_default": true,
"azure_kv": {
"tenant_id": "00000000-0000-0000-0000-000000000000",
"managed_identity_id": null
"aws_kv": {
"role_arn": null
"hashicorp_kv": {}
"snapshot": {
"aks_infra_resource_group": "MC_ci-asaks4002399_ci-asaks4002399_eastus",
"enabled": true,
"account_name": "storaccid2547865",
"auth_mode": "ServicePrincipal",
"bucket_name": "uipath-backup",
"client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e",
"client_secret": "vault/azure-secret-store/snapshot-external-object-storage-client-secret-1234",
"cloud_name": "AzurePublicCloud",
"resource_group": "ci-asaks4002399",
"subscription_id": "b65b0225-ce9b-4a79-9dd9-c00071d40d64",
"sql_connection_string_template": "vault/azure-secret-store/sql-connection-string-template-1234",
"sql_connection_string_template_jdbc": "vault/azure-secret-store/sql-connection-string-template-jdbc-1234",
"sql_connection_string_template_odbc": "vault/azure-secret-store/sql-connection-string-template-odbc-1234",
"sql_connection_string_template_sqlalchemy_pyodbc": "vault/azure-secret-store/sql-connection-string-template-sqlalchemy-pyodbc-1234",
"storage_class": "managed-premium",
"storage_class_single_replica": "azurefile-csi",
"test_manager": {
"enabled": true,
"tolerations": []
"apps": {
"enabled": true,
"enabled": true,
"enabled": true,
"fabric": {
"redis": {
"port": 6380,
"tls": true
"infra": {
"ingress": {
"enabled": true,
"orchestrator": {
"enabled": true,
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"platform": {
"enabled": true
"pod_identity": {
"enabled": true
"profile": "ha",
"proxy": {
"enabled": true,
"registries": {
"docker": {
"password": "",
"username": ""
"helm": {
"password": "",
"username": ""
"secret_store": {
"enabled": true,
"secret_name": "",
"type": "azure",
"is_default": true,
"azure_kv": {
"aws_kv": {
"role_arn": null
"hashicorp_kv": {}
"snapshot": {
"enabled": true,
"test_manager": {
"enabled": true,
"tolerations": []
Configuring the Azure cloud environment
The environment_type field specifies which Azure cloud environment to use for Key Vault access. This field is optional and defaults to PublicCloud.
The following values are supported:
| Value | Description |
PublicCloud | Azure public cloud (default) |
USGovernmentCloud | Azure US Government cloud |
ChinaCloud | Azure China cloud |
GermanCloud | Azure Germany cloud |
The vault_url must match the Azure cloud environment. For example:
- Public cloud:
https://<vault-name>.vault.azure.net/ - US Government:
https://<vault-name>.vault.usgovcloudapi.net/ - China:
https://<vault-name>.vault.azure.cn/ - Germany:
https://<vault-name>.vault.microsoftazure.de/
The following example shows how to configure the environment_type field in input.json:
"secret_store": {
"enabled": true,
"type": "azure",
"environment_type": "USGovernmentCloud",
"azure_kv": {
"secret_store": {
"enabled": true,
"type": "azure",
"azure_kv": {
Using Workload Identity authentication
You can configure Azure Key Vault as a secretstore using Workload Identity authentication instead of a Service Principal.
Workload Identity allows Kubernetes pods to access Azure resources without storing credentials in Kubernetes secrets.
Depending on your setup, you can either use the global workload identity that applies to all components or configure a separate workload identity specifically for Azure Key Vault, as follows:
- Use global workload identity
"pod_identity": { "aks_managed_identity_client_id": "managed-identity-id", "enabled": true }, "secret_store": { "enabled": true, "provider_configs": [ { "type": "azure", "refresh_interval": "5m", "name": "azure-secret-store", "azure_kv": { "vault_url": "https://eso-azure-kv.vault.azure.net/" } } ] }"pod_identity": { "aks_managed_identity_client_id": "managed-identity-id", "enabled": true }, "secret_store": { "enabled": true, "provider_configs": [ { "type": "azure", "refresh_interval": "5m", "name": "azure-secret-store", "azure_kv": { "vault_url": "https://eso-azure-kv.vault.azure.net/" } } ] } - Use a separate workload identity for Azure Key Vault
"secret_store": { "enabled": true, "provider_configs": [ { "type": "azure", "refresh_interval": "5m", "name": "azure-secret-store", "azure_kv": { "vault_url": "https://eso-azure-kv.vault.azure.net/", "managed_identity_id": "managed-identity-id" } } ] }"secret_store": { "enabled": true, "provider_configs": [ { "type": "azure", "refresh_interval": "5m", "name": "azure-secret-store", "azure_kv": { "vault_url": "https://eso-azure-kv.vault.azure.net/", "managed_identity_id": "managed-identity-id" } } ] }
Configuring managed identity for External Secrets Operator
To enable the External Secrets Operator to access Azure Key Vault using workload identity, take the following steps:
Perform the steps described in the Workload identity configuration to provide federated credentials to the required service accounts.
In addition to step 3 of the Workload Identity configuration, run the following command to create federated credentials for the External Secrets Operator:
create_federated_credentials "uipath" "external-secrets"create_federated_credentials "uipath" "external-secrets" -
Assign the required roles to the managed identity so it can access secrets in Azure Key Vault:
# Export the following variables with your correct values export SUBSCRIPTION_ID="<your-subscription-id>" export TARGET_RG="<your-resource-group-name>" export VAULT_NAME="<your-key-vault-name>" export USER_ASSIGNED_MANAGED_IDENTITY_OBJECT_ID="<your-managed-identity-object-id>" # Assign Key Vault roles to the managed identity az role assignment create --assignee $USER_ASSIGNED_MANAGED_IDENTITY_OBJECT_ID --role "Key Vault Secrets User" --scope "/subscriptions/$SUBSCRIPTION_ID/resourceGroups/$TARGET_RG/providers/Microsoft.KeyVault/vaults/$VAULT_NAME" az role assignment create --assignee $USER_ASSIGNED_MANAGED_IDENTITY_OBJECT_ID --role "Key Vault Reader" --scope "/subscriptions/$SUBSCRIPTION_ID/resourceGroups/$TARGET_RG/providers/Microsoft.KeyVault/vaults/$VAULT_NAME"# Export the following variables with your correct values export SUBSCRIPTION_ID="<your-subscription-id>" export TARGET_RG="<your-resource-group-name>" export VAULT_NAME="<your-key-vault-name>" export USER_ASSIGNED_MANAGED_IDENTITY_OBJECT_ID="<your-managed-identity-object-id>" # Assign Key Vault roles to the managed identity az role assignment create --assignee $USER_ASSIGNED_MANAGED_IDENTITY_OBJECT_ID --role "Key Vault Secrets User" --scope "/subscriptions/$SUBSCRIPTION_ID/resourceGroups/$TARGET_RG/providers/Microsoft.KeyVault/vaults/$VAULT_NAME" az role assignment create --assignee $USER_ASSIGNED_MANAGED_IDENTITY_OBJECT_ID --role "Key Vault Reader" --scope "/subscriptions/$SUBSCRIPTION_ID/resourceGroups/$TARGET_RG/providers/Microsoft.KeyVault/vaults/$VAULT_NAME"
Configuring external OCI-compliant private registry
When using a private registry, if you do not want to configure the registry credentials in input.json, you can provide them as a Kubernetes secret instead, as shown in the following example:
"registries": {
"docker": {
"url": "sfbrdevhelmweacr.azurecr.io"
"registries": {
"docker": {
Create the Kubernetes secret that stores the registry credentials, as shown in the following example:
apiVersion: v1
kind: Secret
metadata:
type: Opaque
data:
url: base64Encode(sfbrdevhelmweacr.azurecr.io)
username: base64Encode(<registry-username>)
password: base64Encode(<registry-password>)
apiVersion: v1
kind: Secret
metadata:
type: Opaque
data:
Apply the secret in the uipath namespace using the following command:
kubectl apply -f registry-credentials.yaml -n uipath
