- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Compatibility matrix
Third-party component versions supported by Automation Suite on AKS and EKS.
Azure third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on AKS.
| Prerequisites for Azure | Compatible versions |
| Azure Kubernetes Service (AKS) Architecture | x86 |
| Ubuntu |
| Cloud Redis | Version 6 |
| Microsoft SQL Server | Microsoft SQL Server 2019 and 2022, Standard and Enterprise editions. For product-specific version dependency, refer to SQL database. |
| PostgreSQL | PostgreSQL 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance. |
| Prometheus (if you bring your own) | 3.13.2 |
| Grafana (if you bring your own) | 13.1.3 |
| Alert Manager (if you bring your own) | 0.33.1 |
FluentD/Fluent-bit (if you bring your own)helm-charts: logging-operator, logging-operator-logging | 6.7.0 |
Gatekeeper (if you bring your own)helm-charts: gatekeeper | 3.22.2 |
Velero (if you bring your own)helm-charts: velero | 12.0.3 |
Cert Manager (if you bring your own)helm-charts: cert-manager | 1.20.3 |
Istio (if you bring your own)helm-charts: istio-base | 1.30.3 |
External Secrets Operator (if you bring your own)helm-charts: external-secrets |
AWS third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on EKS.
| Prerequisites for AWS | Compatible versions |
| Elastic Kubernetes Service (EKS) Architecture | x86 |
| Amazon Linux |
| Bottlerocket | 1.48.0 |
| Elasticache | version 6.2.6 |
| Database - RDS | 15.00.4236.7.v1 |
| 6.7.0 |
| 3.22.2 |
| 12.0.3 |
| 1.20.3 |
| 1.30.3 |
Kubernetes compatibility
To receive UiPath® support for a particular Automation Suite Cumulative Update (CU), you must use both an Automation Suite version and a Kubernetes version that are currently supported.
The support calendar for Automation Suite is available in the Product lifecycle section of the Overview guide. For the Kubernetes support calendar, refer to the Kubernetes documentation.
Updating your Kubernetes cluster to a supported version may require updating Automation Suite to a newer CU. For example, if you are on Automation Suite 2.2510.0, the last supported version for your cluster is Kubernetes 1.33. When this version reaches its end of life, you must update your cluster to a newer Kubernetes version. This also requires updating to a newer Automation Suite CU.
The following table lists the Kubernetes versions validated and supported with each Automation Suite 2.2510.x CU.
| Automation Suite version | Compatible Kubernetes versions |
| 2.2510.4 | 1.34, 1.35, 1.36 |
| 2.2510.3 | 1.33, 1.34, 1.35 |
| 2.2510.2 | 1.32 , 1.33, 1.34 |
| 2.2510.1 | 1.32 , 1.33, 1.34 |
| 2.2510.0 | 1.31, 1.32 , 1.33 |
