- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Managing the certificates
Update TLS and identity token-signing certificates in Automation Suite on EKS/AKS.
The installation process generates self-signed certificates on your behalf. These certificates will expire in 90 days. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working in 90 days.
You can use the uipathctl CLI tool to update certificates post-installation. For details, refer to uipathctl documentation.
Generating a Certificate Signing Request (CSR) and a private key
To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN,DNS:apps.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr
[SAN]
EOF
Your IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
Managing the TLS certificate
To view more information about updating the TLS certificates, run the following command:
uipathctl config update-tls-certificates --help
Output:
Manage tls certificates
Usage:
uipathctl config tls-certificates [flags]
uipathctl config tls-certificates [command]
Available Commands:
get Get the current tls certificates
update Update tls certificates
Flags:
-h, --help help for tls-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Finding the TLS certificates
Certificates are stored as a secret at Istio level. You can find certificates under the istio-ingressgateway-certs name in the <istio-system> namespace.
See the certificate files in the following list:
- Server TLS certificate is stored as
tls.crt - Server TLS private key as
tls.key - CA bundle is stored as
ca.crt
You can verify the secrets using the following command:
kubectl -n <istio-system> get secrets istio-ingressgateway-certs -o yaml
Certificates are also stored in the <uipath> namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, refer to Understanding the container architecture related to certificates.
Updating the TLS certificates
Before updating the server certificate, you must decrypt the private key that was generated in the Generating a Certificate Signing Request (CSR) and a private key section. Skipping this decryption step will result in an error.
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key
How the certificate chain is assembled
When you run the uipathctl config tls-certificates update command, uipathctl assembles the full certificate chain from two separate input files:
server.crt- the complete public server certificate chain in PEM format: the leaf server certificate, followed by the intermediate CA certificate(s), and the root CA that form the signing path for that leaf certificate. Include only certificates that are part of the leaf certificate's actual signing chain - do not include sibling, unrelated, duplicate, or alternate CA certificates.ca.crt- the complete CA chain, including all intermediate certificates and the root CA. The file must contain only the certificates used to sign the TLS server certificate. Including anything else will lead to failure.
uipathctl merges these files at runtime.
To update the certificate, provide the path to each of the three certificate files. All certificate files must be in PEM format.
- Certificate Authority Bundle - The complete CA chain used to sign the TLS server certificate. Include all intermediate certificates and the root CA. Do not include the leaf certificate or any other certificates not used to sign the TLS server certificate, as including anything else will lead to failure. The chain limit is up to nine certificates.
- Server Certificate - The complete public server certificate chain in PEM format, starting with the leaf server certificate, followed by the intermediate CA certificate(s), and root CA. Include only the certificates that form the leaf certificate's actual signing chain.
- Private key - Private key for the server certificate.
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key
For troubleshooting TLS certificate validation errors, refer to TLS certificate validation errors.
If you choose to manage the certificates yourself, you must use the --use-istio-cert flag with the certificates update command. This flag allows for the existing secrets to be copied to the uipath namespace. Be aware that, when using the --use-istio-cert flag, you must not use any other certificate flags, otherwise the command fails.
If you use a namespace other than uipath, you must specify it by passing it to the --namespace <uipath> flag, where <uipath> represents the namespace where Automation Suite is deployed.
Accessing the TLS certificate
To print out the certificate files, run the following command:
uipathctl config tls-certificates get
Managing additional CA certificates
To view more information about additional CA certificates, run the following command:
uipathctl config additional-ca-certificates --help
Output:
Manage additional ca certificates
Usage:
uipathctl config additional-ca-certificates [flags]
uipathctl config additional-ca-certificates [command]
Available Commands:
get Get the current additional ca certificates
update Update additional ca certificates
Flags:
-h, --help help for additional-ca-certificates
Global Flags:
Use "uipathctl config additional-ca-certificates [command] --help" for more information about a command.
Usage:
Available Commands:
Flags:
Global Flags:
The following sections describe the operations you can perform using the uipathctl config additional-ca-certificates command.
Updating the CA certificates
To update the CA certificates, take the following steps:
- Update the
input.jsonfile to point to the file withadditional_ca_certs. For details, refer to Certificate configuration. - Apply the manifest:
This command may fail with errors such as:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.jsonIrrespective of the failure, proceed to step 3 to restart deployments and stabilize the environment.Error: [failed to wait for application argocd/<app-name1>: timed out waiting for the condition, failed to wait for application argocd/<app-name2>: timed out waiting for the condition]]Error: [failed to wait for application argocd/<app-name1>: timed out waiting for the condition, failed to wait for application argocd/<app-name2>: timed out waiting for the condition]] - Manually restart all deployments and stateful sets in the
uipathnamespace:kubectl rollout restart deployment -n <uipath> kubectl rollout restart sts -n <uipath>kubectl rollout restart deployment -n <uipath> kubectl rollout restart sts -n <uipath>
To append the old certificates, you must use the get command from the Accessing the CA certificates section and append them in the CA certificate .pem file that you must provide in the additional_ca_certs field.
The CA Certificate bundle file should be a valid .pem format and can have more than one certificate present in it.
To download the already configured CA certificates, run the following command:
uipathctl config additional-ca-certificates get
Managing identity token-signing certificates
Automation Suite offers two methods to manage the rotation of identity token-signing certificates: automatic and manual.
To view more information about identity token-signing certificates, run the following command:
uipathctl config token-signing-certificates --help
Output:
Manage token signing certificates
Usage:
uipathctl config token-signing-certificates [flags]
uipathctl config token-signing-certificates [command]
Available Commands:
automatic-key-management Manage key management
get Get the current token signing certificate
rotate Rotate token signing certificates
update Update future token signing certificate
Flags:
-h, --help help for token-signing-certificates
Global Flags:
Use "uipathctl config token-signing-certificates [command] --help" for more information about a command.
Usage:
Available Commands:
Flags:
Global Flags:
You can use a maximum key length of 4096 bits for signing certificates. We highly recommend you to use a key length of at least 512 bits (64 bytes) as a best practice.
The following section provide details on the operations you can perform using the uipathctl config token-signing-certificates command.
Automatic certificate rotation
Automatic certificate rotation means Automation Suite manages the lifecycle of signing keys. This includes rotating keys every 90 days, announcing new keys 14 days prior to rotation, retaining old keys for 14 days post-rotation, and then deleting them when the 14-day period ends.
If you're upgrading from an older version to 2.2510, automatic certificate rotation is disabled by default. To enable automatic key management, run the following command:
uipathctl config token-signing-certificates automatic-key-management enable
Enabling automatic certificate rotation may result in a downtime of up to one hour.
Automatic certificate rotation is enabled by default for clean Automation Suite installations. To disable automatic key management, run the following command:
uipathctl config token-signing-certificates automatic-key-management disable
If the automatic management feature is disabled, signing certificates need to be updated and rotated manually. For details on manual key management, refer to the documentation on manually updating and rotating the certificate.
Manually updating the certificate
The following command does not replace the existing token signing certificate.
Make sure the certificate you provide is in .pem format. The server.crt file must contain the entire chain, as shown in the following example:
-----server cert-----
-----root ca chain-----
To upload the new certificate to sign the token, run the following command:
uipathctl config token-signing-certificates update --cert server.crt --key server.key
After running the update command, restart the Identity deployment and wait 48 hours before running the rotate command.
Manually rotating the certificate
To rotate or replace the old certificate with the new one, run the following command:
uipathctl config token-signing-certificates rotate
After rotation, restart deployments and stateful sets by running the following commands:
kubectl -n <uipath> rollout restart deploy
kubectl -n <uipath> rollout restart sts
Accessing the certificate
To download the current token signing certificate, run the following command:
uipathctl config token-signing-certificates get
There should be a lead time of approximately 24-48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
Rotating the certificate too soon before the expiry of the cache token can result in downtime. In this case, you may have to restart all your robots.
- Generating a Certificate Signing Request (CSR) and a private key
- Managing the TLS certificate
- Finding the TLS certificates
- Updating the TLS certificates
- Accessing the TLS certificate
- Managing additional CA certificates
- Updating the CA certificates
- Accessing the CA certificates
- Managing identity token-signing certificates
- Automatic certificate rotation
- Manually updating the certificate
- Manually rotating the certificate
- Accessing the certificate
