- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Migrate data and configurations between Automation Suite clusters on EKS/AKS.
About the cluster migration
You can migrate from one Automation Suite cluster to another if you use the uipath namespace instead of a custom namespace and want to move from one Automation Suite flavor to another. We support the following scenarios:
- Migrate from Automation Suite on Linux to a new installation of Automation Suite on EKS/AKS;
- Migrate from Automation Suite on Linux to a new installation of Automation Suite on OpenShift.
Any migration scenario not listed above is not supported.
Note that you can attempt to perform the migration operation multiple times with no impact on your existing cluster.
The following migration scenarios are not supported:
- Migrating from Automation Suite on Linux to an existing installation of Automation Suite on EKS/AKS or Automation Suite on OpenShift;
- Migrating an Automation Suite on OpenShift cluster to Automation Suite on Linux cluster;
- Migrating from Automation Suite on EKS/AKS to a new installation of Automation Suite on OpenShift;
- Migrating from Automation Suite on OpenShift to a new installation of Automation Suite on EKS/AKS;
- Migrating from Automation Suite on EKS to Automation Suite on AKS or from Automation Suite on AKS to Automation Suite on EKS;
- Migrating from Automation Suite on EKS to a new installation of Automation Suite on EKS;
- Migrating from Automation Suite on AKS to a new installation of Automation Suite on AKS;
- Migrating from Automation Suite on OpenShift to a new installation of Automation Suite on OpenShift.
Process overview
The following table provides an overview of the cluster migration process.
| Step | Description |
| 1. | Mandatory . Make sure you meet the migration requirements. |
| 2. | Mandatory. Prepare the target cluster and the docker images for both source and target cluster. Optional. If your deployment is offline or if you use a private OCI registry, make sure the required images are available. |
| 3. | Mandatory. Start the migration, move the data, and run the Automation Suite installation. |
| 4. | Optional . If AI Center is enabled on both the source and target clusters, migrate the skills. |
For detailed migration instructions, refer to the Automation Suite on EKS/AKS Installation Guide.
Requirements
To migrate from an Automation Suite cluster to another, you must meet the following requirements:
- Download the following artifacts:
uipathctlversions.json
- You must establish connectivity between the two environments.
- You must have an external objectstore configured in your source cluster. If you use in-cluster storage, refer to Migrating in-cluster objectstore to external objectstore.
- You must grant the source cluster read/write permissions to the destination object store. When persistent volumes (PVs) are copied, the source cluster writes their data to the destination object store, and then the destination cluster pulls the data from the object store and creates the corresponding PVs.
- If you migrate from Automation Suite on Linux, the version of your source cluster must be 2022.10 or newer.
- If you migrate to Automation Suite on OpenShift, the version of your source cluster must be 2023.10 or newer.
- Offline-only requirements: You must hydrate the target cluster.
Data migration and responsibilities
The following table describes the data migration mechanisms and responsibilities for each component.
| Data | Migration mechanism | |
| Status | Responsibility | |
| SQL | Retained You have two options:
| Customer |
| Docker registry | Not migrated registry.uipath.com for the target cluster, no further steps are needed.) | Customer |
| FQDN | Required You must choose a new FQDN for the new cluster. Optionally, you can revert to the previous FQDN if needed. | Customer |
| Certificates | Not migrated You must bring certificates as part of the new cluster installation. | Customer |
| Cluster configuration | Not migrated input.json applicable to the target cluster type (AKS or EKS). | Customer |
| Custom alerts and dashboards created by users | Not migrated Post-migration, you must reconfigure any custom alerts in Alert Manager and Grafana dashboards. | Customer |
| Application logs / Prometheus streaming configuration created by users | Not migrated You must reconfigure application log and Prometheus streaming. | Customer |
| Dynamic workloads | Depends on application AI Center training jobs are lost; Skills are retained. | Skills (script needed to be executed after upgrade): UiPath® Training jobs: Customer |
| Objectstore | External objectstore: Retained For external objectstore, you have two options:
Important : If you're using an in-cluster object store, you must perform a ceph-to-external migration before the upgrade. | Migrating from in-cluster to external objectstore: Customer External objectstore: UiPath® |
| Insights | Retained | UiPath® |
| MongoDB data | Retained MongoDB data is moved to the target SQL. | UiPath® |
| RabbitMQ | Not needed | UiPath® |
| Monitoring (data) | Not needed Monitoring data does not apply to the new cluster. | N/A |
Preparing the cluster migration
Preparing the target cluster
Do not run uipathctl manifest apply until you have completed Step 1 in the Running the cluster migration section. Running this command too early can result in configuration inconsistencies in the target cluster.
Do not modify the source cluster after starting the migration process.
To prepare the target cluster, take the following steps:
Download the targeted version of
input.jsonon the source cluster and generate theinput.jsonfile by running the following command:uipathctl manifest get-revisionuipathctl manifest get-revisionFor details, refer to the following diagram:
Based on the previously generated
input.jsonfile, modify theinput.jsonfile of the target cluster.You must transfer the Orchestrator-specific configuration that includes the and settings.
Additionally, you must update the following components so that they reference the correct infrastructure in the target cluster:
- External objectstore
- SQL Server or PostgreSQL connection details
- Redis cluster configuration
Note:Dedicated Microsoft SQL Server and PostgreSQL for Process Mining Airflow database is required for Process Mining on Automation Suite 2.2510.
If you migrate from a version prior to 2024.10.3, the generated
input.jsonfile for the target cluster does not contain the connection string for the Airflow PostgreSQL database. To use the latest version of Airflow, which requires PostgreSQL, you will need to manually add thesqlalchemyconnection string template for PostgreSQL to theinput.jsonfile for the target cluster before migration.Postgresql_connection_string_template_sqlalchemy_pyodbcpostgresql+psycopg2://<user>:<password>@<postgresql host>:<postgresql port>/DB_NAME_PLACEHOLDERpostgresql+psycopg2://<user>:<password>@<postgresql host>:<postgresql port>/DB_NAME_PLACEHOLDER -
Validate the prerequisites in the target cluster by running the following command:
uipathctl prereq run input-target.json --kubeconfig kubeconfig.target --versions versions.jsonuipathctl prereq run input-target.json --kubeconfig kubeconfig.target --versions versions.jsonNote:input-target.jsonis theinput.jsonfile corresponding to the target cluster.To generate the
kubeconfigfile, refer to Generating the kubeconfig file. -
If you are migrating from Automation Suite on Linux to a EKS/AKS deployment, you must put the source cluster in maintenance mode. For details, refer to Putting the cluster in maintenance mode.
Clone the SQL databases from the source deployment to the target deployment.
Hydrating the OCI-compliant registry registry without internet access
The migration process requires the latest uipathcore Docker image tag to be available for both the source and target clusters. If your source cluster is offline, make the image available by taking the following steps:
Follow the steps to hydrate the registry used by the target cluster with the offline bundle in Option B: Hydrating the registry with the offline bundle.
Copy the
uipathctlbinary andversions.jsonfile on a VM with access to the source cluster. -
Run the following command:
jq -r '.[][] | select(.name=="uipath/uipathcore") | .ref + ":" + .version' "/path/to/versions.json" > images.txtjq -r '.[][] | select(.name=="uipath/uipathcore") | .ref + ":" + .version' "/path/to/versions.json" > images.txt -
Seed the
uipathcoreimage from the registry of the target cluster to the registry of source cluster:./uipathctl registry seed --tag-file ./images.txt \ --source-registry "target.registry.fqdn.com" \ --source-password "target-registry-username" \ --source-username "target-registry-password" \ --dest-registry "source.registry.fqdn.com" \ --dest-username "source-registry-username" \ --dest-password "source-registry-password"./uipathctl registry seed --tag-file ./images.txt \ --source-registry "target.registry.fqdn.com" \ --source-password "target-registry-username" \ --source-username "target-registry-password" \ --dest-registry "source.registry.fqdn.com" \ --dest-username "source-registry-username" \ --dest-password "source-registry-password"
Make sure to update the command as follows:
- Replace
target.registry.fqdn.com,target.registry.fqdn.com, andtarget-registry-passwordwith the proper values that correspond to the registry associated with the target cluster; - Replace
source.registry.fqdn.com,source.registry.fqdn.com, andsource-registry-passwordwith the proper values that correspond to the registry associated with the source cluster.
Hydrating the OCI-compliant registry with internet access
If you use a private registry, you must seed it. For instructions, refer to Configuring the OCI-compliant registry.
To migrate to the target Automation Suite cluster, take the following steps:
Execute the migration by running the following command:
uipathctl cluster migration run input-target.json --kubeconfig kubeconfig.source --target-kubeconfig kubeconfig.target --versions versions-target.jsonuipathctl cluster migration run input-target.json --kubeconfig kubeconfig.source --target-kubeconfig kubeconfig.target --versions versions-target.json -
Complete the Automation Suite installation on the target cluster by running the following command:
uipathctl manifest apply input-target.json --kubeconfig kubeconfig.target --versions versions-target.jsonuipathctl manifest apply input-target.json --kubeconfig kubeconfig.target --versions versions-target.json
Migrating the AI Center skills
The steps in this section are applicable only if you enabled AI Center on both the source and target clusters. Note that the instructions assume that AI Center on the target cluster points to the database containing the skill data for running the skills.
After completing the migration, you must sync the AI Center skills so that you can use them again.
Checking the skill migration status
You can use the following script to sync the AI Center ML Skill to the target cluster. The script triggers the sync in the background if no active sync is in progress.
The script syncs the skills in the background (async) and returns. The job ensures that the skills are deployed and updates the DB entry to reflect the current status.
uipathctl service aicenter sync-skills [skill_ids]
[skill_ids]: Optional. Array of skill IDs separated by space. If you provide the skill ID, then only those skills are updated; otherwise, all deployed skills are re-synced.
uipathctl service aicenter sync-skills 783273-3232-3232-323 32-32-323-3232
//this will only sync the skills with ID 783273-3232-3232-323 and 32-32-323-3232
To view the status of the AI Center ML Skill, run the following command:
uipathctl service aicenter sync-skill-status [skill_ids]
The command can return any of the following statuses:
InProgess- skill deployment is in progress.Failed- skill deployment is failed.OutOfSync- skill is available in the database; however, it has yet to be deployed.Available- when the skills are deployed and available to consume.
- About the cluster migration
- Process overview
- Requirements
- Data migration and responsibilities
- Preparing the cluster migration
- Preparing the target cluster
- Hydrating the OCI-compliant registry registry without internet access
- Hydrating the OCI-compliant registry with internet access
- Running the cluster migration
- Migrating the AI Center skills
- Checking the skill migration status
