Last updated May 13, 2026
Automation Suite overview
Automation Suite enables you to deploy the UiPath® business automation platform in your environment of your choice. Depending on your needs, you can deploy the platform on Linux servers (bare-metal or virtual machines) in your data center or public cloud (Azure, AWS, or GCP), or on your Kubernetes clusters in Amazon Web Services (Elastic Kubernetes Service) or Microsoft Azure (Azure Kubernetes Service).
Automation Suite includes:
  • All Server Products (except for any new products shipping in Automation Cloud first).
  • All Shared Suite Capabilities that enable you to easily configure the integration with existing enterprise systems, such as AD, AAD, or SAML, across all products; a common experience is offered across the suite for the user, tenant, external applications, and license management.
  • Common end-user portal.
This guide provides documentation for installing Automation Suite on your EKS or AKS clusters.
If you are looking for our classic deployment experience in a Linux environment, refer to the Automation Suite on Linux Installation Guide.
For an in-depth perspective on each deployment model, refer to Cross-deployment model feature comparison.
Key benefits
docs image
Deployment scenarios
You can deploy Automation Suite in an online or offline environment, with or without a proxy.
Security and compliance
Automation Suite is pre-configured with optional OPA policies and network policies to follow the principles of the least privilege. In addition, to control the OPA policies, Automation Suite also bundles an optional Gatekeeper component.
Prerequisites
Before installing Automation Suite, you must make sure that your cluster meets the infrastructure requirements.
Installation
UiPath® provides the uipathctl CLI tool, which handles operations such as running prerequisite validations, installing Automation Suite on your cluster, and performing upgrades.
Post-installation management
Automation Suite provides management operations via uipathctl, such as adding new products, updating certificates, configuring Automation Suite in maintenance mode, taking backups, and monitoring.
Upgrade and migration
This section provides more details on how to upgrade Automation Suite or your infrastructure underneath Automation Suite, and how to migrate from standalone products to Automation Suite.
For details, refer to Upgrade and Migrate standalone products.
Troubleshooting
You can run health checks and tests to help detect issues and whether they are in the infrastructure layer or within Automation Suite.
We aim to provide feature parity between our Automation Suite deployment models. However, there will always be some differences you should be aware of.
If you need to deploy Automation Suite on containerized platforms such as AKS or EKS, refer to the Automation Suite on EKS/AKS Installation Guide.
User scenario/Feature Automation Suite on Linux Automation Suite on AKS Automation Suite on EKS
Service capabilities
Orchestrator
AI Center
AI Center with external orchestrator (standalone)
Apps
Action Center
Automation Hub
Automation Ops
Data Service
Document Understanding
Insights
Automation Suite Robots
Process Mining
Task Mining
Test Manager
Integration Service
Communications mining
Studio Web
Architecture
Kubernetes Rancher RKE2 AKS EKS
Databases
  • MS SQL
Note:
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
  • PostgreSQL for Process Mining Airflow database
Note:
Automation Suite 2023.10.9 or higher.
Storage
  • Option 1: Object Storage (Ceph)
  • Option 2: Object storage external to the cluster
UiPath® provides Ceph.
  • Object Storage: Azure Blob
  • Filesystem: Azure Filesystem
  • Block Storage: Azure Disks
  • Object Storage: AWS S3
  • Filesystem: AWS EFS
  • Block Storage: AWS EBS
Service Mesh and Routing
Rancher provided Istio Service Mesh
Routing via envoy ingress gateway
OSS Istio Service Mesh
Routing via WASM plugin
OPA
OSS Gatekeeper
OSS Gatekeeper
OSS Gatekeeper
Monitoring
Rancher provided Prometheus & Grafana
OSS Prometheus & Grafana
Caching
Embedded Redis with in the cluster and provided by UiPath®
Cloud Redis outside the cluster and managed by customer
Logging Aggregation
Rancher provided Fluend/Fluent-bit
OSS Fluend/Fluent-bit
Cert Manager
OSS Cert Manager
OSS Cert Manager
OSS Cert Manager
Deployment tool
OSS ArgoCD
OSS ArgoCD
OSS ArgoCD
Deployment scenario
Single Node (Non-production)
Multi Node (HA)
✅ (requires additional HAA license)
Online
Offline
Deployment method
Advanced CLI install-uipath.sh
uipathctl
uipathctl
Interactive Installer ✅ ( InstallUiPathAS.sh )
Marketplace
✅ (AWS QS Only)
Installation
A la carte product selection
Custom domain
Custom certificates
Hardware requirements validation
Proxy configuration
Optional OSS/fabric component
Enterprise grade features
Disaster Recovery
✅ (Active Passive deployment)
(Multi-zone architecture for UiPath® services without zone affinity. Insights not supported.)
Backup/restore
Upgrade
Troubleshooting
Support bundle ✅( support-bundle.sh ) ✅ ( uipathctl ) ✅ ( uipathctl )
Diagnostic tool ✅( diagnostics-report.sh ) ✅( uipathctl ) ✅ ( uipathctl )
Health Checks
Security
FIPS enabled host
Gatekeeper/OPA policy
Network policy
Hardened UiPath® service container images
ArgoCD SSO
✅ (LDAP only)
mTLS for service communication
Migration options
Standalone Orchestrator to Automation Suite full migration
Standalone Orchestrator to Automation single tenant migration options
Automation Suite embedded to AS on AKS/EKS
Evaluation guide
Requirements and installation
DetailsInstructions
Requirements and installation instructions for Automation Suite.Automation Suite requirements Automation Suite installation
Platform evaluation
DetailsInstructions
Complete an initial platform configuration.Automation Suite Configuration checklist
Connect your first robot.Connecting Attended Robots
Monitor the stack, troubleshoot issues, create alerts, and view dashboards from a centralized location.Troubleshooting tools Using the monitoring stack
Product evaluation
The following instructions take you to the corresponding product guides.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
