AI Center and Document Understanding pods fail to start with TLS certificate verification enabled
Solutions for pod startup failures with TLS verification in Automation Suite on EKS/AKS, including volume mount configuration.
Description​
When database TLS certificate verification is enabled (trustservercertificate=false in the SQL connection string), some AI Center and Document Understanding pods may get stuck in Init:CrashLoopBackOff. The await-migration-completion init container fails to connect to the database, with TLS/SSL handshake errors in the logs.
Solution​
To address the issue, take the following steps:
  1. Disable Auto-Sync for AI Center and Document Understanding in ArgoCD.
  2. Manually add the following volume mounts to the await-migration-completion init container in each affected deployment.
    For aistorage and aistorage-cleanup:
    - mountPath: /etc/pki/ca-trust/extracted/java/
    - mountPath: /etc/pki/ca-trust/extracted/edk2/
    - mountPath: /etc/pki/ca-trust/extracted/pem/
    - mountPath: /etc/pki/ca-trust/extracted/openssl/
    - mountPath: /etc/pki/ca-trust/source/anchors/
    For du-digitizer and du-digitizer-cleanup:
    - mountPath: /etc/ssl/certs
    - mountPath: /usr/local/share/ca-certificates
    Note:
    These volumes are already defined at the pod level and only need to be mounted into the init container.
  3. Enable Auto-Sync again.
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
