- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring log rules
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Perform database maintenance for Insights in Automation Suite on EKS/AKS.
Insights Database works using two tables: dbo and read. Both tables store data from Orchestrator databases and pass data between each other. Over time, tables store a large amount of data that can impact database performance. You can free up space by removing data that is not relevant or outdated.
The estimated threshold for storing historical data is set to
- Up to 100 million jobs
- Up to 1 billion job events
- Up to 100 million queue items
- Up to 500 million queue item events
- Up to 1 billion robot logs
Use the following database maintenance SQL scripts to create SQL Stored Procedures, then execute these SQL Stored Procedures to either delete all data from [dbo].Jobs, [dbo].JobEvents, [dbo].QueueItems, [dbo].QueueItemEvents, [dbo].RobotLogs tables, or just the [dbo].RobotLogs.
Back up your database before executing the scripts. Before running the PROCEDURE [read].[Delete_Insights_Data_Read] and PROCEDURE [read].[Delete_Process_Logs_Read] scripts, the Insights module needs to be disabled.
Considerations
- Scripts with the
_DBOsuffix are used to delete data from DBO schema tables, - Scripts with the
_Readsuffix are used to delete data from Read schema tables. - Large-sized batches might impact the speed of execution. Consider using the default batch size, which is set to 100000.
Prerequisites
Log in to the Automation Suite cluster.
Remove files that may conflict with the commands:
rm -f appsettings.jsonrm -f appsettings.json -
Get the current settings:
uipathctl config orchestrator get-config --app-settings > appsettings.json || echo '{}' > appsettings.jsonuipathctl config orchestrator get-config --app-settings > appsettings.json || echo '{}' > appsettings.jsonNote:Ignore the following message if it is displayed:
Cannot print custom config: Orchestrator custom config is missing appsettings.. This error message only implies there are no custom settings. -
Add the
Insights.ModuleEnabledkey and set it toFalse:jq '.["Insights.ModuleEnabled"] = "false"' appsettings.json > temp.json && mv -f temp.json appsettings.jsonjq '.["Insights.ModuleEnabled"] = "false"' appsettings.json > temp.json && mv -f temp.json appsettings.json -
Update the configuration:
uipathctl config orchestrator update-config --app-settings appsettings.jsonuipathctl config orchestrator update-config --app-settings appsettings.json -
Validate the configuration:
uipathctl config orchestrator get-config --app-settingsuipathctl config orchestrator get-config --app-settingsThe expected result is as follows:
{ "Insights.ModuleEnabled": "false" }{ "Insights.ModuleEnabled": "false" }The result can contain other settings unrelated to Insights.
Run the maintenance scripts. After you run the maintenance script, re-enable Insights using the following steps.
Remove any conflicting files:
Remove the
Insights.ModuleEnabledkey:jq 'del(.["Insights.ModuleEnabled"])' appsettings.json > temp.json && mv -f temp.json appsettings.jsonjq 'del(.["Insights.ModuleEnabled"])' appsettings.json > temp.json && mv -f temp.json appsettings.json -
Confirm the configuration:
{}{}The result can contain other settings unrelated to Insights.
Resources
SQL stored procedure 1: delete all data based on cut-off timestamp
Generate and save the following SQL Stored Procedures to delete all data types (Jobs, JobEvents, QueueItems, QueueItemEvents, RobotLogs) for a cut-off timestamp.
| SQL Stored Procedures | Parameter | Description |
| Delete_Insights_Data_DBO |
| Delete data from [dbo].[Jobs], [dbo].[JobEvents], [dbo].[QueueItems], [dbo].[QueueItemEvents], [dbo].[RobotLogs] tables based on a cut-off timestamp. |
| Delete_Insights_Data_Read | N/A | Truncate [read].Jobs, [read].JobEvents, [read].QueueItems, [read].QueueItemEvents, [read].RobotLogs tables. |
The Insights Dashboard widgets are available again after SQL Stored Procedure 1 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data.
When you first run the Delete_Insights_Data_DBO SQL Script, it creates a QueueItems.IX_CreationTime nonclustered index with the purpose of making future executions faster.
SQL stored procedure 2: delete RobotLogs data based on ProcessNames and Tenant ID
Generate and save this SQL Stored Procedure to delete RobotsLogs based on ProcessNames and Tenant ID.
| Delete_Process_Logs_DBO |
The Orchestrator process name.
Tenant ID is required as two tenants might run processes with identical names.
Delete data in batches of 100000. For details, refer to Considerations. | Delete data from [dbo].[RobotLogs] table by ProcessName and Tenant ID. |
| Delete_Process_Logs_Read |
| Truncate [read].RobotLogs table. |
The Insights Dashboard widgets related to RobotLogs are available again after SQL Stored Procedure 2 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data.
