Pods in the uipath namespace stuck when enabling custom node taints
Solutions for pod startup failures with custom node taints in Automation Suite on EKS/AKS.
Description​
Pods in the <uipath> namespace are not running when custom node taints are enabled. The pods cannot talk to the adminctl webhook that injects pod tolerations in an EKS env.
Solution​
To fix the issue, create a network policy to allow traffic into the admctl webhook from the cluster CIDR or 0.0.0.0/0.
kind: NetworkPolicy
apiVersion: networking.k8s.io/v1
metadata:
  namespace: <uipath>
spec:
  podSelector:
    matchLabels:
      app: admctl-webhook
  ingress:
        - ipBlock:
            cidr: <cluster-pod-cdr> or "0.0.0.0/0"
kind: NetworkPolicy
metadata:
  namespace: <uipath>
spec:
  podSelector:
    matchLabels:
      app: admctl-webhook
  ingress:
        - ipBlock:
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
