- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Patch artifact download links
Links to download patch artifacts for Automation Suite on EKS/AKS.
This page provides the download links for the artifacts required to apply a patch.
2.2510.4 patches
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2.2510.4 patches.
2.2510.4+patch1
uipathctl
To download uipathctl for Automation Suite 2.2510.4+patch1, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4-patch1/uipathctl-2.2510.4-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.4+patch1/as-cmk-2.2510.4+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.4+patch1/air-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.4+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.4+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.4+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2.2510.4+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.4+patch1/versions.json
2.2510.2 patches
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2.2510.2 patches.
2.2510.2+patch2
uipathctl
To download uipathctl for Automation Suite 2.2510.2+patch2, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch2/uipathctl-2.2510.2-patch2-darwin-amd64.tar.gz
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2.2510.2+patch2, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch2/as-cmk-2.2510.2+patch2.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.2+patch2, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.2+patch2/air-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.2+patch2, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2+patch2/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.2+patch2, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch2/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.2+patch2, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch2/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2.2510.2+patch2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.2+patch2/versions.json
2.2510.2+patch1
uipathctl
To download uipathctl for Automation Suite 2.2510.2+patch1, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2-patch1/uipathctl-2.2510.2-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2.2510.2+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.2+patch1/as-cmk-2.2510.2+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.2+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.2+patch1/air-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.2+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.2+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.2+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2.2510.2+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.2+patch1/versions.json
2.2510.1 patches
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2.2510.1 patches.
2.2510.1+patch1
uipathctl
To download uipathctl for Automation Suite 2.2510.1+patch1, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1-patch1/uipathctl-2.2510.1-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2.2510.1+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.1+patch1/as-cmk-2.2510.1+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.1+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.1+patch1/air-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.1+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.1+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.1+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.1+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.1+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.1+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2.2510.1+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.1+patch1/versions.json
2.2510.0 patches
This section provides the download links for the artifacts required for Automation Suite on EKS/AKS 2.2510.0 patches.
2.2510.0+patch1
uipathctl
To download uipathctl for Automation Suite 2.2510.0+patch1, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0-patch1/uipathctl-2.2510.0-patch1-darwin-amd64.tar.gz
as-cmk.tar.gz
To download as-cmk.tar.gz for Automation Suite 2.2510.0+patch1, run the following command:
wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.0+patch1/as-cmk-2.2510.0+patch1.tar.gz
as-images.txt
To download as-images.txt for Automation Suite 2.2510.0+patch1, run the following command:
wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.0+patch1/air-images.txt
as-helm-charts.txt
To download as-helm-charts.txt for Automation Suite 2.2510.0+patch1, run the following command:
wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.0+patch1/embedded-helm-charts.txt
mirror-registry.sh
To download mirror-registry.sh for Automation Suite 2.2510.0+patch1, run the following command:
wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.0+patch1/mirror-registry.sh
hydrate-registry.sh
To download hydrate-registry.sh for Automation Suite 2.2510.0+patch1, run the following command:
wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.0+patch1/hydrate-registry.sh
versions.json
To download versions.json for Automation Suite 2.2510.0+patch1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.0+patch1/versions.json
