- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Durable Execution Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Upgrading Automation Suite
Perform major and minor version upgrades of Automation Suite on EKS/AKS.
Automation Suite consists of multiple components. Both you as a customer and UiPath® share responsibility of these components. For details, refer to Responsibility matrix.
You are responsible for upgrading:
- Kubernetes infrastructure where Automation Suite is deployed (AKS or EKS)
- Components that you choose to bring as part of Automation Suite (e.g., Gatekeeper, FluentD, etc.)
UiPath® is responsible for upgrading:
- UiPath® services (e.g., Orchestrator)
- Components deployed as part of Automation Suite (e.g., ArgoCD)
Upgrading UiPath® services and components
Preparation
- If you upgrade to Automation Suite 2.2510, you need to bring a PostgreSQL database for
AutomationSuite_Airflowand configure the connection string for it ininput.json. For details, refer to Process Mining-specific configuration. - If you upgarde from versions prior to 2.2510.0 using Studio Web, make sure to use the same storage class name as specified
in
storage_class_single_replica, to support RWX access mode. For details, refer to Configuring input.json.
Additionally, review the following database maintenance guidance before starting the upgrade.
Very large Automation Suite database tables can cause database migration jobs to take much longer or fail to complete during the upgrade. Keeping database tables well-maintained reduces this risk.
We recommend archiving or purging data that is no longer needed from high-volume tables before starting the upgrade; for details, refer to Performing database maintenance.
To prepare for the upgrade, take the following steps:
Check the compatibility matrix to determine the supported versions for each available upgrade scenario. If you brought your own components, make sure the versions of your components are compatible with the version you plan to upgrade to. For details, refer to Compatibility matrix.
Download
versions.jsonanduipathctlfor the version you want to upgrade to, on your management machine. For download instructions, refer to Downloading the installation packages. -
Generate the latest
input.jsonfile as follows:- Option A: To get the latest revision of your
input.jsonfile, run the following command:uipathctl manifest get-revisionuipathctl manifest get-revision - Option B: To list all the past
input.jsonfiles and determine the one you want to choose, run the following command:uipathctl manifest list-revisionsuipathctl manifest list-revisions
If you are using an offline setup with an external OCI-compliant registry, you must hydrate the registry with container images and Helm charts before upgrade. For details, refer to Hydrating the registry with the offline bundle.
If Process Mining is installed, and you want to use latest version of Airflow which needs PostgreSQL, you must add or update the
sqlalchemyconnection string template applicable for PostgreSQL in theinput.jsonfile before the upgrade:postgresql_connection_string_template_sqlalchemy_pyodbc.postgresql+psycopg2://<user>:<password>@<postgresql host>:<postgresql port>/<airflow db name>postgresql+psycopg2://<user>:<password>@<postgresql host>:<postgresql port>/<airflow db name> -
If Integration Service is installed, make sure your external cloud queues (SQS) are synced and cross-region replication is enabled. For example:
- In Azure Queue Storage, configure the GRS/RA-GRS or GZRS/RA-GZRS redundancy options. For details, refer to:
- In Amazon SQS, create SQS queues in each region and replicate messages using SNS fan-out or custom logic. For details, refer to:
If you upgrade to Automation Suite 2.2510.0 or later from previous Automation Suite 2024.10 versions and have Studio Web enabled, you must also enable Solutions. For details, refer to Enabling or disabling Solutions. Make sure you also review the additional hardware requirements for Solutions. For details, refer to Capacity Planning.
Execution
To perform an upgrade of UiPath® services and component, take the following steps:
Confirm that your cluster is healthy:
uipathctl health check --namespace <uipath> --versions versions.jsonuipathctl health check --namespace <uipath> --versions versions.json -
Put the cluster in maintenance mode to guarantee a consistent backup:
uipathctl cluster maintenance enableuipathctl cluster maintenance enableImportant:This operation causes downtime, and your business automation is suspended while maintenance mode is enabled.
Verify that the cluster is in maintenance mode:
uipathctl cluster maintenance is-enableduipathctl cluster maintenance is-enabled -
Back up the cluster and the SQL database, then check that the backup completed successfully. Create a backup before upgrading your Kubernetes infrastructure as well.
If you simultaneously meet the following requirements, make sure to copy the value of
global.userInputs.identity.krb5KeytabSecrettoglobal.kerberosAuthConfig.userKeytab:- you configured the Active Directory integration using username and password
- you have Windows authentication enabled
- you do not use SQL integrated authentication
Starting with Automation Suite 2.2510.2, maintenance mode must remain enabled during the upgrade. For versions earlier than Automation Suite 2.2510.2, disable maintenance mode before performing the upgrade:
uipathctl cluster maintenance disableuipathctl cluster maintenance disableNote:If you are upgrading to Automation Suite 2.2510.2 or later, skip this step and disable maintenance mode only after the upgrade completes.
Perform the upgrade of UiPath® services and components:
uipathctl cluster upgrade input.json --versions versions.jsonuipathctl cluster upgrade input.json --versions versions.jsonIn Automation Suite 2.2510.0, the
uipathctl cluster upgradecommand fails with the following error when maintenance mode is disabled:Please enable maintenance mode prior to attempting an upgrade. Use 'uipathctl cluster maintenance enable'.To avoid the error message, use the following command to perform the upgrade. Make sure you have created all required backups before proceeding.
uipathctl cluster upgrade input.json --versions versions.json --skip-upgrade-readinessuipathctl cluster upgrade input.json --versions versions.json --skip-upgrade-readinessImportant:This operation causes downtime, and your business automation is suspended during the upgrade process. It is important that you perform the upgrade only during your maintenance window.
Starting with Automation Suite 2.2510.2, disable the maintenance mode:
uipathctl cluster maintenance disableuipathctl cluster maintenance disable -
Check that the cluster is healthy after the upgrade:
uipathctl health check --namespace <uipath> --versions versions.jsonuipathctl health check --namespace <uipath> --versions versions.jsonNote:If you upgraded to Automation Suite 2.2510 or higher, you can uninstall Dapr and Cert Manager, if you previously installed these add-ons for Process Mining or Task Mining. For details, refer to the Uninstall Dapr and Uninstall Cert Manager sections.
Upgrading Kubernetes infrastructure
Automation Suite supports upstream N-1 to N-3 versions of Kubernetes irrespective of the cloud provider. For instance, if upstream is 1.27, we support versions 1.26, 1.25, and 1.24. For supported versions, refer to the Compatibility matrix.
You are responsible for upgrading the Kubernetes infrastructure hosting Automation Suite. You should follow the standard practices of your company to upgrade Kubernetes infrastructure.
Performing post-upgrade operations
The following scenarios describe which post-upgrade operations are required for your environment:
If you upgraded to Automation Suite 2.2510.0 or higher and Process Mining or Task Mining was enabled on the previous version:
- Uninstall Dapr. For details, refer to How to uninstall Dapr.
- Uninstall Cert Manager. For details, refer to How to uninstall Cert Manager.
If you upgraded to Automation Suite 2.2510.0 or newer, you must immediately reactivate your existing licenses for each organization and host:
- Online activation: Reactivate directly after upgrade.
- Offline activation: Generate a new activation payload file from the Automation Suite instance, then upload it in Activation.
Reusing old activation files is not allowed and will result in an invalid license. License reactivation must be performed using the Update License button. Do not manually deactivate and then reactivate the license, as doing so disables services.
