- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Backing up and restoring the cluster
Configure backups and restore functionality for Automation Suite on EKS/AKS.
Automation Suite provides backup and restore functionality to help prevent data loss in various scenarios. You can configure backups at any time after installation. Although backups are optional, enabling them is strongly recommended to ensure that you can recover the environment to a consistent state in the event of a disaster.
Backups use the cloud provider's managed backup solution, which leverages native cloud capabilities to unify and simplify your organization's backup and recovery strategy.
