Basic architecture considerations
Infrastructure, latency, datasource, management, RTO, and RPO considerations for multi-site Automation Suite on EKS/AKS.
As with any multi-site deployment, the primary architecture considerations for Automation Suite account for infrastructure, latency, data source, management, Recovery Time Objective, Recovery Point Objective, etc.
Infrastructure
We recommend using the same hardware for both clusters. However, the Automation Suite cluster will likely work with similar hardware configurations with little difference. Heterogeneous hardware may increase complexity and slow down troubleshooting.
Management
The two Automation Suite clusters are independent and do not share any configuration. Therefore, any management or maintenance activity must be done individually on these clusters. For instance, you must update the SQL connection strings on both clusters, configure certificates separately, etc. In addition, you must monitor the two clusters independently, upgrade them individually, etc.
Datasource
The objectstore, combined with the SQL database, forms the state of an installed product on Automation Suite.
SQL Server configuration
SQL Server configuration plays a vital role in a multi-site deployment. Though SQL Server is a component external to Automation Suite, a few additional steps are required to ensure true HA when working with Automation Suite.
The SQL Server must be configured in the Always On Availability Group or failure over groups. It must be spread across both sites to ensure accurate High Availability when one site is down. Both clusters must use the same SQL listener endpoint in the connection string. Furthermore, it is recommended to set the MultiSubnetFailover=True property in the connection string when the SQL server/databases are distributed across multiple subnets.
PostgreSQL server configuration
Like SQL Server, PostgreSQL is external to Automation Suite, but a few additional steps are required for true HA in a multi-site deployment. PostgreSQL is used by Process Mining, Autopilot for Developers, and Temporal as a Service. For disaster recovery, the Autopilot for Developers must be replicated to the secondary site. The Process Mining database does not require cross-site replication. TaaS is not supported in the secondary cluster; it is supported only in the primary site in an A/P deployment.
Configure a primary PostgreSQL server in Site 1 with physical replication to at least one read-only standby in Site 2, and point both clusters at the current primary through a single endpoint. In the event of a disaster, promote the Site 2 standby to primary and update the endpoint to point to Site 2.
External objectstore configuration
The external objectstore is immune to possible corruption due to node failure. Data replication and disaster recovery can be carried out independently of Automation Suite. Like SQL Server, the external objectstore must be configured in a highly available Disaster Recovery setup.
The primary objectstore instance is physically located in the primary data center, and at least one secondary instance is located in the secondary data center with data sync enabled. You can configure a load balancer on the objectstore to ensure both Automation Suite clusters refer to the same endpoints. This makes the deployment independent of how the objectstore is configured internally.
Important:
For AWS S3, the multi-region access point does not support all the s3 APIs required by all the products running in Automation Suite. For details on the list of support APIs, refer to Using Multi-Region Access Points with supported API operations.
You can create two buckets per product/suite in both regions and enable synchronization. The Automation Suite cluster running in the same region will refer to the buckets in the same region.
Your organization's policy around RTO is vital in designing your multi-site Automation Suite cluster. To achieve the desired RTO, take the following aspects into consideration:
  • Design of the Traffic Manager;
  • Availability of the nodes in the secondary/passive cluster;
  • Dynamic workload availability on the secondary cluster; for example, MLSkill;
  • Configuration Management.
Traffic Manager
To unlock the full potential of both clusters, it is crucial to configure the Traffic Manager appropriately. The setup should ideally facilitate the distribution of traffic to both clusters. This strategy not only ensures a balanced load distribution, but also safeguards business continuity, mitigating any potential disruptiveness if either site experiences a complete shutdown.
Nodes availability
In the event of a disaster that results in one site becoming entirely non-operational, the other site must have enough capacity to ensure that business automation is not impacted. Insufficient capacity at the functioning site may negatively affect the running of the business and potentially lead to significant operational issues.
A few products, such as AI Center, deploy the ML Skills dynamically at the runtime. The deployment of the skills in another cluster is always asynchronous. This cannot guarantee their availability. To ensure that your automation solution returns online within the desired time, you can periodically sync the skills in another cluster.
Configuration management
Since multi-site Automation Suite deployments consist of two distinct clusters, any operation performed on any cluster must be performed on the other cluster in time to reduce the drift. This ensures that both clusters possess similar configurations and that no additional effort is required during recovery.
Your organization's policy around Recovery Point Objective (RPO) is vital in designing your multi-site Automation Suite cluster. To achieve the desired RPO, you must take the following aspects into account:
  • Data synchronization;
  • Scheduled backup.
When written to the primary data source, data must also be synced to the secondary cluster. However, there is a risk of data loss when the data center is down, and data is not synced. Exemplary network configurations, such as high bandwidth and low latency between the two data centers, can speed up synchronization.
Scheduled backup
Not all disaster recovery provides complete immunity to data loss. However, you can deploy a regular and periodic backup strategy to minimize the impact of the disaster on data recovery. For details, refer to Backing up and restoring the cluster.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
