- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
EKS input.json example
Example input.json file with all products enabled and configuration parameters for Automation Suite on EKS.
The following example shows input.json with all products enabled, mandatory and optional configuration parameters for Automation Suite on EKS. You can use this as reference and make changes as per your environment requirements.
Note that the minimum UiPath® product selection requires platform to be enabled. Make sure to replace all the username and passwords, including SQL connection strings.
"kubernetes_distribution": "eks",
"install_type": "online",
"profile": "ha",
"network": {
"ipv4": { "enabled": true },
"ipv6": { "enabled": true }
"registries": {
"docker": {
"url": "registry.uipath.com",
"username": "",
"password": ""
"helm": {
"username": "",
"password": ""
"fqdn": "automationsuite.mycompany.com",
"admin_username": "admin",
"admin_password": "password123",
"fips_enabled_nodes": false,
"fabric": {
"redis": {
"license": "", // fabric.redis.license must not be specified when fabric.redis.{hostname, password, port} are specified
"ha":false,
"hostname": "redis-cache.mycompany.com",
"password": "redispassword",
"port": 6380,
"tls": true
"pod_identity" : {
"enabled": true,
"aks_managed_identity_client_id": <client-id>
"external_object_storage": {
"enabled": true,
"create_bucket": true,
"storage_type": "azure",
"use_managed_identity": false,
"azure_fqdn_suffix": "core.windows.net",
"account_key": "secretkey",
"account_name": "as-storage-account",
// storage type s3 specific config:
"fqdn": null,
"port": null,
"region": "us-east-1",
"access_key": "",
"secret_key": "",
"use_instance_profile": true,
"bucket_name_prefix": "",
"bucket_name_suffix": ""
"ingress": {
"service_annotations": {
"service.beta.kubernetes.io/aws-load-balancer-backend-protocol": "ssl",
"service.beta.kubernetes.io/aws-load-balancer-eip-allocations": "<elastic_ip_id_0>,<elastic_ip_id_1>",
"service.beta.kubernetes.io/aws-load-balancer-nlb-target-type": "ip",
"service.beta.kubernetes.io/aws-load-balancer-scheme": "internet-facing",
"service.beta.kubernetes.io/aws-load-balancer-type": "nlb"
"gateway_selector": {
"istio": "ingressgateway"
"istio_gateway_service_name": "istio-ingressgateway"
"istioMinProtocolVersion": "TLSV1_3",
"disable_presigned_url": false,
"tolerations": [],
"exclude_components": [],
"server_certificate": {
"tls_cert_file": "",
"tls_key_file": "",
"ca_cert_file": ""
"additional_ca_certs": "",
"registry_ca_cert": "",
"identity_certificate": {
"saml_current_service_cert_file": "",
"saml_current_service_cert_pass": "",
"saml_future_service_cert_file": "",
"saml_future_service_cert_pass": "",
"ldap_cert_authority_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"infra": {
"bucket_name": "s3-sfd-ci-aseks3997852-common"
"dataservice": {
"bucket_name": "s3-sfd-ci-aseks3997852-dataservice"
"enabled": true
"platform": {
"enabled": true
"integrationservices": {
"queue_prefix": "<queuePrefix>",
"account_id":""
"enabled": true,
"studioweb": {
"enabled": true,
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"bucket_name": "s3-sfd-ci-aseks3997852-processmining"
"enabled": true
"semanticproxy": {
"enabled": true
"insights": {
"enabled": true,
"enable_realtime_monitoring": false,
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"aicenter": {
"bucket_name": "s3-sfd-ci-aseks3997852-common",
"port": 443,
"fqdn": "s3.eu-west-1.amazonaws.com"
"enabled": true
"documentunderstanding": {
"enabled": true
"test_manager": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"ecs": {
"enabled": true,
"sql_connection_str": "",
"sql_vector_connection_str": "",
"external_object_storage": null,
"llmobservability": {
"enabled": true,
"trace_retention_in_days": 30,
"llmaudit_retention_in_months": 24,
"llmgateway": {
"enabled": true,
"automationsolutions": {
"enabled": true,
"autopiloteveryone": {
"enabled": true,
"maestro": {
"enabled": true,
"taas": {
"enabled": true
"a4d": {
"enabled": true,
"bucket_name": "uipath-as-a4d"
"asrobots": {
"packagecaching": true,
"packagecachefolder": "/uipath_asrobots_package_cache",
"enabled": true
"agents": {
"enabled": true,
"storage_class": "ebs-sc",
"storage_class_single_replica": "efs-sc",
"storage_class_name_with_rwx_support": "efs-sc",
"proxy": {
"enabled": true,
"http_proxy": "http://<PROXY-SERVER-IP:<PROXY-PORT>",
"https_proxy": "http://<PROXY-SERVER-IP:<PROXY-PORT>",
"no_proxy": "paste list from Configuring the cluster section"
"sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1433;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:sqlpassword@mssql.mycompany.com:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server",
"postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
"postgresql_connection_string_template_sqlalchemy_asyncpg": "postgresql+asyncpg://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
"telemetry_optout": false
"profile": "ha",
"network": {
"registries": {
"docker": {
"username": "",
"password": ""
"helm": {
"username": "",
"password": ""
"fabric": {
"redis": {
"ha":false,
"port": 6380,
"tls": true
"pod_identity" : {
"enabled": true,
"enabled": true,
"fqdn": null,
"port": null,
"access_key": "",
"secret_key": "",
"ingress": {
"tolerations": [],
"tls_key_file": "",
"ca_cert_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"infra": {
"dataservice": {
"enabled": true
"platform": {
"enabled": true
"account_id":""
"enabled": true,
"studioweb": {
"enabled": true,
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"enabled": true
"semanticproxy": {
"enabled": true
"insights": {
"enabled": true,
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"aicenter": {
"port": 443,
"enabled": true
"enabled": true
"test_manager": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"ecs": {
"enabled": true,
"enabled": true,
"llmgateway": {
"enabled": true,
"enabled": true,
"enabled": true,
"maestro": {
"enabled": true,
"taas": {
"enabled": true
"a4d": {
"enabled": true,
"asrobots": {
"enabled": true
"agents": {
"enabled": true,
"proxy": {
"enabled": true,
Note:
If Maestro does not receive a bucket name, it defaults to uipath-as-taas.
