- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Durable Execution Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Disaster recovery - Active/Passive
Disaster recovery architecture and product support for Active/Passive deployments in Automation Suite on EKS/AKS.
This article walks you through the core concepts and architecture of Automation Suite disaster recovery, covering Active/Passive deployments.
Ensuring continuous business automation is at the core of any automation platform. Automation Suite can withstand the complete failure of nodes, entire data centers, or regions. You can deploy Automation Suite as an Active/Passive configuration.
Automation Suite multi-site deployments in Active/Passive mode support the following scenarios:
- Same-region deployment - Two Automation Suite clusters deployed in the same region;
- Cross-region deployment - Two Automation Suite clusters deployed in different regions.
The following table provides details on which Automation Suite products you can deploy in Active/Passive mode.
| Product | Support for Active/Passive |
| Orchestrator | ✅ |
| Action Center | ✅ |
| Agents | ❌ |
| AI Center | ✅ |
| Apps | ✅ |
| Automation Ops | ✅ |
| Automation Suite Robots | ✅ |
| Computer Vision | ✅ |
| Data Service | ✅ |
| Document Understanding | ✅ |
| Test Manager | ✅ |
| Automation Hub | ✅ |
| Healing Agent | ✅ |
| Insights | ✅ |
| Process Mining | ✅ |
| Integration Service | ✅ |
| LLM gateway | ✅ |
| LLM observability | ✅ |
| ECS | ✅ |
| ScreenPlay | ✅ |
| Semantic Proxy | ✅ |
| Studio Web | ✅ |
| Autopilot for Everyone | ✅ |
| Maestro | ❌ |
| Durable Execution Service | ❌ |
| Autopilot for developers | ✅ |
| Solutions | ✅ |
- You can install products that are not supported in Disaster Recovery with Active/Passive . However, you cannot use these products when the primary cluster is down.
- For AI Center, the training pipeline functionality is available only in the primary cluster.
Requirements
To configure an Active/Passive deployment, make sure you meet the following requirements:
- Hardware
- Database
- Amazon Elastic Cache (Redis)
- S3 (Object Store)
- SQS (Queues)
- Route 53
- Product-specific requirements
Hardware
The secondary (Passive) hardware cluster must be identical to the Primary hardware cluster.
Database
The database must be accessible from both the Active and Passive clusters.
The system must operate separately for both the Active cluster and the Passive cluster.
S3 (Object Store)
The S3 system must be synchronized and it must support Cross-Region Replication (CRR).
SQS (Queues)
SQS must operate separately on Active and Passive setups.
Route 53
Route53 must be used to control the routing of traffic. Configuration in Route53 is required to direct traffic to the active load balancer when functional.
In case of a disaster, the traffic must be re-routed to the passive load balancer using route 53.
If your deployment includes Studio Web or Insights, you must enable backup and restore for their persistent volumes (PVC-backed data) to ensure these products can recover properly during failover and failback. For details, refer to:
