- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Solutions for External Secrets Operator issues in Automation Suite on EKS/AKS.
This section provides troubleshooting steps for resolving issues related to the External Secrets Operator and secretstore configuration in Automation Suite.
To identify and resolve synchronization or authentication issues between your cluster and the external secret provider, follow the steps described in this section.
Verify External Secrets pod status and logs
Begin by checking that the External Secrets Operator pods are running correctly.
If the pods are not in a Running state or show repeated restarts, review their logs for any errors related to authentication, permissions, or misconfiguration.
To check the status of the External Secrets pods and view their logs, run:
kubectl get pods -A | grep external-secrets
kubectl logs -f <pod-name> -n <namespace>
For example, to view logs from a specific pod, run:
kubectl logs -f external-secrets-7d8c9b5f9f-abc12 -n external-secrets
Inspect SecretStore and ExternalSecret objects
If the pods are running correctly, verify that the SecretStore and ExternalSecret resources are properly configured and synchronized.
These resources define how external secrets are retrieved and stored, so any misconfiguration can prevent successful synchronization.
- Check ExternalSecret resources Start by reviewing the ExternalSecret objects in your cluster. This helps confirm that the resources are correctly linked to their SecretStore and that the sync status is valid.
- To display and inspect your ExternalSecret resources, run the following commands:
kubectl get externalsecrets -A kubectl describe externalsecret <externalsecret-name> -n <namespace>kubectl get externalsecrets -A kubectl describe externalsecret <externalsecret-name> -n <namespace> - For example, to review a specific ExternalSecret in the
uipathnamespace:kubectl describe externalsecret azure-secret-store -n uipathkubectl describe externalsecret azure-secret-store -n uipath
- Check SecretStore resources Inspect the associated SecretStore configuration. This resource defines the connection details for your secret provider (such as Azure Key Vault), and errors here can block secret synchronization.
- To review the SecretStore definitions, use the following commands:
kubectl get secretstores -A kubectl describe secretstore <secretstore-name> -n <namespace>kubectl get secretstores -A kubectl describe secretstore <secretstore-name> -n <namespace> - For example, to examine a SecretStore configuration in the
uipathnamespace:kubectl describe secretstore azure-secretstore -n uipathkubectl describe secretstore azure-secretstore -n uipath
- Check events related to External Secrets Review any Kubernetes events related to the External Secrets Operator. These events can reveal synchronization failures, permission issues, or provider misconfigurations.
To view related events, run the following command:
kubectl get events -A | grep external-secretskubectl get events -A | grep external-secretsWhen reviewing the event output, look for:
- Error messages in the Status section
- Conditions indicating whether
Ready: True - Warnings or synchronization failures in the Events section
Verify Secret Store credentials
If you are using Azure Key Vault as your secret provider, ensure that the credentials and configuration are valid and up to date.
Incorrect credentials or missing permissions are common causes of synchronization failures.
- Authentication credentials
- Confirm that the
clientId,clientSecret, andtenantIdvalues are correct. - Ensure the service principal has the required permissions for the Key Vault.
- Confirm that the
- Key Vault access policies
- Verify
GetandListpermissions for secrets. - Ensure the Key Vault firewall settings allow access from your cluster.
- Verify
- Workload identity configuration (if applicable)
- Check that federated credentials are correctly configured.
- Ensure the associated service account has the necessary annotations.
- Key Vault URI
Verify that the
vaultUrlin your SecretStore configuration is correct.Example format:
https://<key-vault-name>.vault.azure.net/https://<key-vault-name>.vault.azure.net/
Verify Azure Key Vault service principal permissions
If your deployment uses a service principal, confirm that it has access to retrieve secrets from Azure Key Vault.
To list the secrets accessible to your service principal, run:
az keyvault secret list --vault-name <key-vault-name>
Verify HashiCorp Vault connectivity and authentication
If you are using HashiCorp Vault as your secret provider, verify the following:
Test Vault server reachability Confirm that the Vault server URL in your SecretStore configuration is reachable from a node or jumphost that has network access to the cluster:
curl -sk https://<vault-server>:8200/v1/sys/healthcurl -sk https://<vault-server>:8200/v1/sys/healthA healthy Vault returns a JSON response with
"initialized": trueand"sealed": false. If the command times out or returnsconnection refused, check network policies and firewall rules between the cluster and the Vault server. -
Verify Vault seal status
curl -sk https://<vault-server>:8200/v1/sys/seal-statuscurl -sk https://<vault-server>:8200/v1/sys/seal-statusIf
"sealed": true, the Vault server must be unsealed before ESO can retrieve secrets. -
Test Kubernetes Auth login If using
auth_type: kubernetes, verify that a service account token can authenticate to Vault. First, extract the token from the ESO pod:ESO_POD=$(kubectl get pods -n uipath -l app.kubernetes.io/name=external-secrets -o jsonpath='{.items[0].metadata.name}') JWT=$(kubectl exec -n uipath $ESO_POD -- cat /var/run/secrets/kubernetes.io/serviceaccount/token)ESO_POD=$(kubectl get pods -n uipath -l app.kubernetes.io/name=external-secrets -o jsonpath='{.items[0].metadata.name}') JWT=$(kubectl exec -n uipath $ESO_POD -- cat /var/run/secrets/kubernetes.io/serviceaccount/token)Then test the login:
curl -sk --request POST \ --data "{\"jwt\": \"$JWT\", \"role\": \"<vault-role>\"}" \ https://<vault-server>:8200/v1/auth/<mount-path>/logincurl -sk --request POST \ --data "{\"jwt\": \"$JWT\", \"role\": \"<vault-role>\"}" \ https://<vault-server>:8200/v1/auth/<mount-path>/loginA successful response contains a
client_token. Apermission deniederror indicates the Vault role does not allow the service account, or the Kubernetes Auth method is misconfigured. -
Test AppRole Auth login If using
auth_type: approle, verify the AppRole credentials:curl -sk --request POST \ --data '{"role_id": "<role-id>", "secret_id": "<secret-id>"}' \ https://<vault-server>:8200/v1/auth/<mount-path>/logincurl -sk --request POST \ --data '{"role_id": "<role-id>", "secret_id": "<secret-id>"}' \ https://<vault-server>:8200/v1/auth/<mount-path>/loginIf this fails, check that the AppRole
secret-idhas not expired (secret_id_ttl). -
Verify the AppRole credentials secret exists
kubectl get secret <credentials-secret-name> -n uipath -o json | jq '.data | keys'kubectl get secret <credentials-secret-name> -n uipath -o json | jq '.data | keys'The secret must contain both
role-idandsecret-idkeys. -
Test reading a secret from Vault KV v2 Using a Vault token obtained from the auth steps above:
curl -sk -H "X-Vault-Token: <vault-token>" \ https://<vault-server>:8200/v1/<kv-path>/data/<secret-path>curl -sk -H "X-Vault-Token: <vault-token>" \ https://<vault-server>:8200/v1/<kv-path>/data/<secret-path>For KV v1, remove
/data/from the path. If the response isno value found at path, verify thathashicorp_kv.versionmatches the actual engine version. -
Verify KV engine version Ensure the
hashicorp_kv.versionin your configuration matches the actual KV engine version enabled in Vault (v1orv2). A mismatch producesno value found at patherrors because v1 and v2 use different API paths. -
Verify Kubernetes Auth configuration Ensure the Vault Kubernetes Auth method is enabled and configured with the correct
kubernetes_host. Verify the Vault role allows the ESO service account (or customservice_account_name).
Verify AWS Secrets Manager connectivity and permissions
If you are using AWS Secrets Manager as your secret provider, verify the following:
Verify the access key credentials secret exists
access-key-idandsecret-access-keykeys. -
Test AWS Secrets Manager access Using the access key credentials, verify that the secret can be retrieved:
aws secretsmanager get-secret-value \ --secret-id <secret-name> --region <region>aws secretsmanager get-secret-value \ --secret-id <secret-name> --region <region>AccessDeniedException- the IAM user does not havesecretsmanager:GetSecretValuepermission.ResourceNotFoundException- the secret does not exist in the specified region. Verify theaws_kv.regionvalue.
Check region configuration Verify the
aws_kv.regionvalue matches the region where your secrets are stored. A region mismatch producesResourceNotFoundExceptionerrors.
TLS and CA certificate issues
When the Vault or AWS endpoint uses HTTPS with a private CA certificate, verify the following:
Check if the additional CA certificate secret exists
kubectl get secret additional-ca-certificates -n uipathkubectl get secret additional-ca-certificates -n uipath -
Verify the CA certificate content
kubectl get secret additional-ca-certificates -n uipath -o jsonpath='{.data.ca\.crt}' | base64 -d | openssl x509 -text -nooutkubectl get secret additional-ca-certificates -n uipath -o jsonpath='{.data.ca\.crt}' | base64 -d | openssl x509 -text -nooutCheck that the certificate is not expired and that the issuer matches the CA used by your Vault or AWS endpoint.
Test TLS handshake
curl -v https://<vault-server>:8200/v1/sys/healthcurl -v https://<vault-server>:8200/v1/sys/healthIf you see
SSL certificate problem: unable to get local issuer certificate, the CA certificate is not being trusted. Verify thatadditional_ca_certsis configured ininput.json. To test with a specific CA certificate file:curl -v --cacert /path/to/ca.crt https://<vault-server>:8200/v1/sys/healthcurl -v --cacert /path/to/ca.crt https://<vault-server>:8200/v1/sys/health
Common configuration issues
Review the following common issues and corresponding error messages to help diagnose the problem.
| Issue | Possible cause | Example / error output |
| Secret not found in cluster | Missing Kubernetes secret | Warning InvalidProviderConfig 3s (x4 over 8s) secret-store cannot get Kubernetes secret "azure-service-principal-secret" from namespace "uipath": secrets "azure-service-principal-secret" not found |
| Invalid credentials | Incorrect client ID, client secret, or tenant ID | error processing spec.data[0] (key: external-object-storage-account-key-10176524), err: azure.BearerAuthorizer#WithAuthorization: Failed to refresh the Token for request ... StatusCode=400 |
| Missing Key Vault object | Key not present in Azure Key Vault | external-secrets error processing spec.data[0] (key: external-object-storage-account-key), err: Secret does not exist |
| HashiCorp Vault unreachable | Incorrect server URL or network policy blocking access | connection refused or context deadline exceeded |
| Vault auth failed | Kubernetes service account not bound to Vault role, or expired AppRole secret-id | permission denied |
| KV version mismatch | hashicorp_kv.version set to v2 but engine is v1 (or vice versa) | no value found at path |
| AWS credentials invalid | Incorrect access key ID or secret access key | InvalidClientTokenId or SignatureDoesNotMatch |
| AWS secret not found | Secret does not exist in the configured region, or region mismatch | ResourceNotFoundException |
To further investigate these issues, review the controller logs or describe the related resources:
kubectl describe externalsecret <name> -n <namespace>
kubectl describe secretstore <name> -n <namespace>
- Overview
- Verify External Secrets pod status and logs
- Inspect SecretStore and ExternalSecret objects
- Verify Secret Store credentials
- Verify Azure Key Vault service principal permissions
- Verify HashiCorp Vault connectivity and authentication
- Verify AWS Secrets Manager connectivity and permissions
- TLS and CA certificate issues
- Common configuration issues
