Configuring Orchestrator parameters
Configure Orchestrator parameters through input.json for Automation Suite on EKS/AKS.
Manifest configuration​
Follow these steps to edit the Orchestrator manifest configuration:
  1. Edit the input.json file. For details, refer to Configuring input.json.
  2. Add or edit the desired settings in the orchestrator section.
  3. Run the following command:
    uipathctl manifest apply input.json --versions versions.json --kubeconfig kubeconfig.yaml --only orchestrator
Custom Orchestrator configuration​
You can use the following command to edit the Orchestrator custom configuration for both appSettings and NLog:
uipathctl config orchestrator
Custom Orchestrator scenarios​
You can modify various Orchestrator parameters using uipathctl. This enables the following configuration scenarios:
  • Manifest configuration​
  • Custom Orchestrator configuration​
  • Custom Orchestrator scenarios​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
