Preparing the installation
Prepare infrastructure, gather requirements, and plan deployment before installing Automation Suite on EKS/AKS.
To prepare the installation, complete the following steps:
  1. Downloading the installation packages
  2. Configuring the OCI-compliant registry
  3. Granting installation permissions
  4. Configuring input.json
  5. Installing and configuring the service mesh
  6. Installing and configuring the GitOps tool
  7. Meeting the product-specific prerequisites
  8. Applying miscellaneous configurations
  9. Checking the infrastructure prerequisites
Note:
To indicate namespace values that you can modify using the input.json file, such as <istio-system> and <uipath>, we enclose them in angle brackets. For details on configuring namespace values, refer to Configuring input.json.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
